Pre 84 Trucks 1st gen pickups
reverse poping out of gear??????????
Old 02-04-2008, 08:21 PM
raygun's Avatar
I have a 79 20R w/4 speed tranny. It pops out of reverse, I bought it this way. Does anyone know how to fix this or does it require a rebuild?
Old 02-04-2008, 08:26 PM
camo31_10.50's Avatar
mine would pop out of first gear...i took a look under one day while i was changing the oil...turns out the reason why is becausesome of the T-case bolts were loose...and some of the tranny bolts were loose...so i took a socket set and tightened every bolt i could find everywhere on the truck..turns out alot of them were loose...so check all that...it sure helped mine
Old 02-04-2008, 08:38 PM
CyMoN's Avatar
theres a shifter bushing that wears out that will cause it to pop out of gear I bought one from wab fab it helped mine but I think my syncro is going out on my first gear I have just got used to holding the shifter when in first gear.
the bushing is a lot cheaper to start with compared to rebuilding the tranny.
Old 02-04-2008, 08:39 PM
rowdy235's Avatar
Can you hold it in reverse or does it push your hand out.
Old 02-04-2008, 08:55 PM
raygun's Avatar
Thanks all. Yes I can hold it reverse. It doesn't feel like the gears are meshing completly. Like there riding on the edge of each other.
Old 02-04-2008, 09:21 PM
Jay351's Avatar
Make sure the shifter is not binding on the shift boots.
Old 02-05-2008, 06:22 AM
rowdy235's Avatar
IIRC, if you can hold it in reverse, the shift bushing is at fault. At least do that before rebuilding, as others have mentioned.
Old 02-05-2008, 08:22 PM
raygun's Avatar
Thanks will try the bushing and also the seat on the shifter lever. There are aftermarket heavy duty ones here.
http://www.marlincrawler.com/htm/transmission/1a.htm
Old 02-05-2008, 08:33 PM
Jay351's Avatar
Yep, marlin is the way to go. I installed their shifter seat and bushing when I put in my clutch. One of the best mods you can do for the price.
JAmdor3
08-11-2015 10:53 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
mengquis
07-13-2015 10:39 AM
Poncho0206
07-10-2015 06:21 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: reverse poping out of gear??????????
