Pre 84 Trucks 1st gen pickups
Pulling front axle, have a few questions
Old 10-05-2011, 11:58 AM
southernZ's Avatar
So im finally in the process of pulling the front axle on my '80. Going to rebuild the knuckles, sand it down and repaint. I am wanting to leave the knuckle arms, tie-rod, and drag link all attached to the axle when i pull it so i can pressure wash everything before i start sanding. This means i need to pull the drag link end off the pitman arm. I have been working on getting it off for the last hour with no luck. Any tips??
Old 10-05-2011, 12:59 PM
Tbeck792's Avatar
PB over night, if that doesn't work you can try taking a torch to it....... or a pitman puller if you're into doing things the right way.
Old 10-05-2011, 04:25 PM
southernZ's Avatar
A Pitman arm puller will do me no good. I am taking the Drag link off of the Pitman arm ball stud.......anyways i got it off, just took a little persuasion and patience.
Old 10-05-2011, 07:21 PM
tazz76's Avatar
i used a chisel and some persuasion from a 4lb sledge to get mine off
Old 10-05-2011, 07:53 PM
Holmgren's Avatar
harbor freight sells a pitman arm puller for like 5$ if you dont wanna do that get a small torch some chisels and a BFH just my .02
bigjstang
08-25-2021 12:41 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Cplmike
07-08-2015 08:47 PM
ItsJustD
07-07-2015 07:49 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Pulling front axle, have a few questions
