Oil and Amp Gauge
Oil and Amp Gauge
So when I'm driving around the oil gauge goes up to the 4 thats around 45+mph it stays there is that a good thing or to low of pressure. I know flow is more important then pressure.
Also the amp gauge doesn't move one bit at all stays at that spot.
Oil Gauge is the 2 4 6 mean pounds? 20 pounds 40 pounds 60 pounds?
these guages are pretty basic .. amp meter wont move much .
If you look at it ,The meter is 50+ or 50- .. and your truck is only running at ~ 14 .. so it wont move much .
The oil pressure guage , it is measured in kg/cm2 , which for you guys(americans) who decided to stay on the "imperial measurement system" this is METRIC as most of the rest of the world measures things
Thanks again Slacker!
88yodabasket
07-13-2015 01:32 PM
