Pre 84 Trucks 1st gen pickups
MY first Toyota 1980 4x4
Old 06-09-2012, 10:03 PM
  #41
1980yota's Avatar
well if you can see it you best belive it CRACK lol so this is what I find after replacing the blow oil pan gasket that I thought was sparying oil on my exhuast well it was but this had its factor in it two. now my bro who works with small engine all day every bay says that REAL STEEL should hold it it ain't to big but you can stick a razor blade knife in it. so what do ya'll think Obama engineer it or get a used block now and rebuild. cheapest way please. I'm broke but I know people that can get a complete motor for 200.
Old 06-09-2012, 11:17 PM
  #42
MikeyC's Avatar
I like it! keep on trucking!
Old 06-10-2012, 04:59 PM
  #43
tazz76's Avatar
High temp jb weld and keep on goin lol got a 70 model charger with a 440 with jb weld on the block of it so it will hold
Old 06-10-2012, 07:46 PM
  #44
1980yota's Avatar
Ok thanks tazz you answered my question!
Old 06-10-2012, 08:07 PM
  #45
tazz76's Avatar
Take a dreamel tool and mat a grove on th crack and go like a inch to the top and bottom of the crack don't have to be deep just a small grove clean the area up some brake cleaner works best and applie the stuff I checked we used water weld cause the temp rating on it was 500 degree but make sure it in the crack good and there's no such thing as to much
Old 06-23-2012, 07:23 PM
  #46
1980yota's Avatar
20r/22r hybrid Maybe?
well got the crack on the block fixed but just bought 2 not one but 2 22rs for 100 one is togather but will be rubilt and one was took apart to be rebuilt but never was. Im wonting to know if i can do the hybrid with this engine they are both the same but they look like the 85s (squared valve cover) and wont to do the hybird but think the engine is to newer.
there is the one thats all togather but going to do it with the one apart they are both the same motor.
Old 06-25-2012, 08:37 AM
  #47
tazz76's Avatar
I think its a pre 85 judging by the timing chain cover but if I'm wrong someone will correct me
Old 06-25-2012, 05:20 PM
  #48
1980yota's Avatar
I think my brothers was the same and his was a 85. but i dont know.
Old 06-29-2012, 07:55 PM
  #49
85toy's Avatar
judging by the valve cover those are too new you need early 84 or older which will have a rounded valve cover.
bigjstang
08-25-2021 12:41 AM
God's Bounty Hunter
07-08-2015 12:54 PM
HRDC0R19
07-05-2015 06:43 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: MY first Toyota 1980 4x4
