Pre 84 Trucks 1st gen pickups
my '83 p/u
Old 02-07-2012, 04:06 PM
quazy65's Avatar
my '83 p/u
first off im new to yt. I inherited my uncles 1983 toyota p/u and i need so ideas to help it run better and stronger. i need things to be cheap since im only 15 and dont have a job. the truck sat behide a barn since 1994 and has problems. it will crank but wont idle and now the freeze plug decided to spring a leak so im waitin to get a new one. so till i get that ive been searching it for other problems like rust. does any one no where some hidden spots are at for rust. i havent found any but on bolts, bed, and surface rust on the frame.
does any one know where i might find a good cheap long bed at in north carolina. i will hopefully get some pics up soon.
Old 02-07-2012, 04:13 PM
nightstalker's Avatar
you will have to take your carb off and clean it, its prob gummed up from sitting, if yuo find a bed, it aint gonna be cheap. if you got deep pockets, they sell fiberglass beds
Old 02-07-2012, 04:18 PM
quazy65's Avatar
no deep pockets, but we are planning on getting a weber 32/36 for carb cuz we bought a rebuild kit took one look and i said forget it and my dad said maybe then a friend of ours who owns a shop said it would be best to go ahead and buy a new one.
so is the weber the best route or is there a better carb out there.
Old 02-07-2012, 04:28 PM
weber 32/36 is a great choice, just follow the set up directions, if you can, dont get the 2 piece adapter, there junk and leak like crazy
Old 02-07-2012, 04:31 PM
quazy65's Avatar
ok thanks
is ebay a good place to buy them or should i go to a automotive store?
Old 02-07-2012, 04:37 PM
lol, depends, im too cheap for new, craigslist is good, my buddy just picked up a almost new one at junk yard for 40 bucks! ebay will work. check out redline performance, or weber direct
Old 02-07-2012, 04:42 PM
quazy65's Avatar
ok i will thanks
Attached Thumbnails my '83 p/u-0305111643.jpg
Old 02-07-2012, 04:58 PM
DrSnow's Avatar
Looks like great project truck. Bed is most susceptible to the rust.
Old 02-09-2012, 04:46 PM
quazy65's Avatar
i have found a 32/36 carb on ebay and i need to know if it is a good one. below is the link
http://www.ebay.com/itm/TOYOTA-PICKU...ht_2415wt_1270
Old 02-09-2012, 05:05 PM
bjlambert's Avatar
That looks legit, but you should definately ask the seller a lot of technical questions and really get under their skin, just to be sure.
Old 02-12-2012, 06:09 AM
quazy65's Avatar
finally got my freeze plug hopefully it will work and no more are cracked
Old 02-12-2012, 09:20 AM
JonnyBoy's Avatar
That's the right Weber kit, except that's the 2 piece spacer that is rather poorly cast and leaks often times. You should still get that kit, the other aftermarket adapters for the carb to the manifold won't have all the other goodies to hook up the pcv and stuff for the carb, just get either LCE's spiral bore adapter or the 1 piece adapter made by Trans-dapt. Summit and others have that one, LCE is the only one that carries the spiral bore. It's a 2 piece adapter, but machined instead of cast so it seals easily. And in the case you ever have to remove the carb, the top gasket is plastic, so it's reusable.
Get an adjustable regulator, too. Best recommendation there seems to be the Holley brand regulator.
Good luck, and enjoy wrenching!
Old 02-17-2012, 06:53 AM
quazy65's Avatar
I am running the stock gears and everything so I was wondering how much it might suffer in proformence when running 35" tires. Next what could I do that's cheap but can get me more power and fuel encomy. I am probably going to get a flat bed and put on it so how much will it suffer in proformence with the 35" or 32"
Old 02-17-2012, 12:50 PM
83's Avatar
A LOT. My 83 was kind of a dog with 31's. I mean you can do it, lot's of people do, but you aren't going to be using 5th gear.
Best next mod, if you go with bigger tires, is the correct gears.
Old 02-17-2012, 04:46 PM
slacker's Avatar
go bottle collecting and save those pennies !!
I say the best mod you could do , is add a winch .. it'll get you home !!
Old 02-23-2012, 02:57 PM
quazy65's Avatar
yesterday i tried to get the old freeze plug off but it dont wont to come off, so what is the best way to get it off? so far we put a hole bout the size of a dime and tried to pull but nothing. i have heard that you can take a flat head screw driver and hammer and tap on the lip of it till it is sideways and then you can pull it out? my dad said that seem impossible so is it or can it be turned in its spot then pulled out?
Old 03-01-2012, 08:26 PM
Staff
kawazx636's Avatar
I would get a job! These trucks can be rather cheap to work on, but its more addictive than crack. Once you turn a wrench, you just can't stop! None-the-less, good luck to you!
Old 03-01-2012, 08:35 PM
Staff
kawazx636's Avatar
I have a 83 short box. I'm running 31 x 10.5's with a weber carb, full exhaust (2.5" all the way back), completely de-smogged and a 3" lift. I get consistently get fuel economy in the 20MPG neighborhood. My truck is a daily driver with 132,000 miles on a motor that has been been rebuilt. I don't do any crawling or anything crazy, but I take it on the beach, through the mud and hunting all the time with absolutely no problem. I've been places that Jeeps have been stuck in, but it's still practical for eveyday use at the same time. If MPG's are what you're going for then 35's are not for you. I switched to 31's about a month ago after having 33's and I'm getting an extra 5-6 MPG with the 31's, just food for thought.
Old 03-06-2012, 04:11 PM
quazy65's Avatar
i have been looking around on the internet and have found a website that might have a carb. that might work. i was just wondering if anyone could tell me if any of the carb kits come with a one piece adapter or are they all a two piece adapter?
heres the link: http://www.partsgeek.com/catalog/198...retor_kit.html
thanks again for all the help
Old 03-07-2012, 05:58 AM
83Toyota88's Avatar
I just put a a new set of 33x12.50 on my 83 (the 3" suspension lift I have is next) and I'm not worried about mpg's but I have wondered if I need different gears but no idea what to go to. And my speedometer is 7-10 mph off now.
Quick Reply: my '83 p/u
