L50 input bearing
#42
Word of advice, fill the gear oil up before you put it in the truck because it takes forever through the fill hole. I taped a funnel to the shifter and ran a hose through the shifter assembly down to the fill hole. Gear oil pours real slow though.
#43
Yep. I've sat under my truck for a long time, with a little hand pump, pumping fluid into the transmission...then t-case...I was probably under there pumping oil for almost an hour.
#44
Can someone tell me if it's my transmission or what but when I get to around 60 mph it gets so loud like a deep roar and vibrates the truck bad. I really need to diagnose this problem what could this be its a 1982 pickup 4x4 and I'm a new owner just trying to solve some issues I have and get more familiar with the truck
#45
Sounds to me more like your tires aren't balanced. The transmission bearings sound bad in certain gears. If its the input bearing it will whine in neutral sitting still.
#46
I really don't think its the tires I mean it sounds fine but when I get to 60 all of a sudden it is so loud I just can't explain it and a vibration, I would think if it was tires it wouldn't just so it at a certain mph
#50
Could be a driveshaft. Doesn't get noticeable untll
You get it spinning the right speed. Put the rear on jack stands and run it through the gears and watch it.
justdifferentials
09-05-2015 06:52 PM
