how should i fix frame
ok, so got under my truck just to see HOW bad the frame is and well on both sides behind the cab, is rotted out, how do i go about fixing this? do i cut it out and build a new peice, cut just the sides of the frame and weld in patches?, just say screw it and buy a new frame?
manitoba canada, i will get up some pics tomorrow, well so far i can stick 4 fingers wide in the ginormous rust hole, i was to scared to pick at it, the frame might fall on me LOL
It is possible to fix but a pain in the a$$. Double check everywhere too make sure the whole frame is not rotted out. I snapped my frame in half behind the cab a few years back, and still was able to fix it. Its been 3 years and its solid as can be still and it even passed an safety inspection. It wasnt easy thats for sure.
Having built rear clips of trucks for air irde and such. I would say fix it! It's not hard. Two things to remember.Can you weld? Can you get a hold of 1/4" plate steel? If the answer to those two questions is yes then go for it! Just make sure you cut out all that rust.Then go and brace it.
yes, i can weld, and yes i can get a hold of ANY kind of steel, but i only have a 110 volt welder, i will probably have to bring it to school and weld it so i have a 220 volt one, i will be doing a frame off soon as i can get it to school, so then i can do the POR-15 treatment after i am all done, and another question, can i buy rockers and cab corners and weld them on, or do i have to make em(witch isent really a problem just a PITA )
JustMike
04-21-2016 07:08 PM
FS[PacSouthWest]: FS: 1988 4RUNNER FRAME 4X4 IFS Located in Lancaster Ca
4x4-runner
08-30-2015 08:55 AM
4x4-runner
08-02-2015 09:24 AM
