Pre 84 Trucks 1st gen pickups
Fan shroud label...
Old 07-25-2014, 03:09 PM
81 Toyo's Avatar
Fan shroud label...
Can someone tell me what's on the yellow label on the fan shroud?......my labels are there but the text is long gone.......would like to find repos if available. Thanks
Old 07-25-2014, 08:21 PM
Staff
kawazx636's Avatar
It says "Place hand below when engine is running" LOL
I've never seen one but I imagine it is some sort of safety warning about the fan.
Old 07-26-2014, 03:53 AM
81 Toyo's Avatar
Originally Posted by kawazx636
It says "Place hand below when engine is running" .
There's a comedian in every crowd!....haha...
Old 07-26-2014, 04:26 PM
slacker's Avatar
could it be this
I have been looking for a good "candidate" for a while , as well as the one on the overflow tank
Old 07-27-2014, 05:44 AM
gillesdetrail's Avatar
I don't think you can see it in this pic, but it might be useful in a way!
Last edited by rworegon; 07-27-2014 at 12:43 PM. Reason: Removed unfamily friendly text.
Old 08-02-2014, 12:17 PM
1st Gen Crawler's Avatar
^ That is one pretty looking engine bay. Gilles, have you rebuild everything, or just kept it beautiful for all of these years?
Old 08-02-2014, 01:57 PM
81 Toyo's Avatar
That looks like a brochure pic.....can you make out the yellow decal on the valve cover?
Old 08-02-2014, 01:59 PM
81 Toyo's Avatar
Originally Posted by slacker
could it be this
My overflow tank decal is in good shape...will post a pic tommorow
Old 08-02-2014, 02:02 PM
Danger, that is a Toyota's middle name.
Old 08-02-2014, 11:12 PM
Staff
kawazx636's Avatar
I have to go check my pants.....
Old 08-03-2014, 09:52 AM
81 Toyo's Avatar
[QUOTE=slacker;
.[/QUOTE]
See if this helps Slacker.....can't help you on the last line of Japanese..
Old 08-03-2014, 12:30 PM
Haha that isn't my engine bay, I wish!
81toyo, from what I can see it says (the x is what I can't see)
CAUTION
use only API ''xx''
or better grade
engine oils
Old 08-03-2014, 04:33 PM
slacker's Avatar
thanks .. that'll work !
Old 09-14-2014, 06:26 AM
subaholic's Avatar
Fan shroud label
Hey 81Toyo, my '83 still has the label on the fan shroud. It gives instructions/cautions for adjusting the belt tension for the air pump....there is some text that instructs to pry on the rear cover, don't pry on the aluminum body. It also say's not to oil the pump. On the lower right there's a diagram of the pump with the correct and incorrect prying locations and where not to oil.
Does this help?
Old 09-14-2014, 02:23 PM
81 Toyo's Avatar
Thanks guy......every one Ive seen is faded beyond legibility.....your engine bay must be in nice shape for that label to have survived.
kawazx636
10-06-2021 03:03 PM
voiddweller
09-28-2015 11:21 PM
Matthew Perez
09-28-2015 05:43 PM
runnermedic
13
09-21-2015 05:20 PM
reallynotamechanic
09-20-2015 05:40 PM
Quick Reply: Fan shroud label...
