Pre 84 Trucks 1st gen pickups
Clutch adjustment
Old 05-13-2014, 04:14 AM
Jcat5503's Avatar
Clutch adjustment
The clutch in my 82 bites as soon as it leaves the floor. Sometimes I have trouble getting it into gear. Is there a way to adjust it?
Old 05-13-2014, 05:04 AM
83's Avatar
There is an adjustment at the clutch pedal linkage, where it goes into the master cylinder. I don't remember the exact procedure but you can probably find it if you search, or use your repair manual (a must for anyone with these trucks. get an FSM if you can).
Old 05-13-2014, 05:08 AM
Jake28296's Avatar
There's a YouTube video on adjusting it its not hard check your fluid too just look up toyota pickup clutch adjustment
Old 05-13-2014, 07:24 AM
Staff
kawazx636's Avatar
It would be impossible for the actual pedal assembly to just come out of adjustment unless you have adjusted the pedal before or maybe a PO did. I would bleed it first. You could have air in the fluid that may be compressing just enough for the clutch to barely disengage with the flywheel when you have the pedal completely pressed but allowing it to be squishy enough to engage early when releasing the pedal. Check your flare fittings at the clutch master cylinder and the fittings on the rubber hose going to the slave cylinder to make sure everything is tight and there are no signs of leakage. Make sure that the rubber hose is in good condition too. If it is swelling then that will result in lower hydraulic pressure and could be causing your problem. If you need to replace it, Marlin or some company now offers a braided stainless slave cylinder hose now.
he's gone
7
12-03-2019 07:08 AM
89fourrunner
02-17-2016 06:52 AM
akamon808
3.4 Swaps
12-16-2015 08:45 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
1996Taco
07-20-2015 12:02 AM
Quick Reply: Clutch adjustment
