Pre 84 Trucks 1st gen pickups
bleeding LSPV
Old Sep 26, 2008 | 04:20 PM
Scooby098's Avatar
bleeding LSPV
I just replaced my MC, and I bench bleed it and did everything the way it came off. I did the search and it said to bleed the LSPV last. But it dosnt have a bleeder valve. I got lots of petal with out bleeding it so far so I beilve it was a bad mc that was causeing my brakes to vanish at times, and have to be pumped up. my question is do I have to bleed it and if so how?
Old Sep 26, 2008 | 05:28 PM
4Crawler's Avatar
There should be a bleed fitting up high on the LSPV itself. It might be covered with dirt, but it should be there.
Old Sep 27, 2008 | 10:19 AM
Scooby098's Avatar
ok will look thanks
Old Oct 2, 2008 | 10:57 PM
Scooby098's Avatar
So Is it normal to have the dustboot full of fuild is that a indication of it gone bad? Cause I was gonna bleed it there is no bleeder there. so I took the boot down just to see cause I was having problems getting my system bleed. cause I had to put in another MC cause the one I bought 6 days ago failed.
Pri$erulz
Nov 17, 2019 08:03 PM
4.34runner88
Feb 7, 2016 02:24 AM
Scatterbrain
Sep 27, 2015 08:24 AM
scheuvront1993
Sep 17, 2015 06:17 PM
old87yota
Sep 9, 2015 12:39 PM
