| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
#27 (permalink) |
i hit a couple of questions, 1: when i was taking the front end out i ook some shims off that i thought were just plates, now i dont know which way the go. does any one know??
2: are these suposed to be different?( wraps around the axle housing for the ubolts to go through) |
#28 (permalink) |
another question. i have a 4 speed manual in it right now but i also have a 5 speed in the barn outside. a buddy of mine was talkin about how another buddy of mine with an almost identical setup couldnt touch 5th gear. he said i should get the tranny re-geard so the gears are lower so that it would be like a 4 speed with a granny low, untill i heard this i was just gonna run dual t-cases. does anyone have more info on the topic for me? gearing is kinda confusing for me.
#29 (permalink) | ||
Quote:
Quote:
CB
__________________
Christopher 1991 Toyota SR5 X-tra Cab, SAS, 4.3 Vortec, 42" Swampers, 5.29:1 gears. Last edited by cblackard; 07-29-2009 at 09:15 AM. |
#30 (permalink) |
Staff
i would get a ubolt flip kit for the front... well worth the 50 bucks.
looks like you got a sweet lil project there.... let me know if you need any Trail-gear parts. i am a TG dealer and live just up in tacoma.... we should go wheelin sometime!
__________________
94 4runenr: all the good stuff....... 89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs. 81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s pacific-crawlers.com For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :) |
#31 (permalink) |
awsome thanks for the help
#32 (permalink) |
I don't know about regearing the tranny, but you could definitely regear the axles. The axle/differential is what people put different gears in to help with bigger tires. So yeah, your gears are for 28" tires. You put those big tires on and your gear ratio to tire size is thrown way off so you lose all your power. Going to different gears (like 4.88 or so) will return you to close to stock set up, so you'll actually be able to move those tires. Not sure what the effect of the dual t-cases will be on this, but I don't know that it will effect your 2wd performance at all.
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock |
#33 (permalink) |
This site has several calculators to use for regearing. I was using 5.29:1 gears with 38" Swampers and the stock V6 with excellent results. The speedometer was even close to being accurate.
http://www.offroaders.com/info/tech-...alculators.htm The trick is if you get it wrong, you have to live with it or buy another set of gears. If you are not sure about the gear ratio you want, or you get a ton of conflicting suggestions, try the calculator and buy just the set for the rear axle. if you think it's too much or too little, change it out accordingly. Then buy the matching gears for the front. CB
__________________
Christopher 1991 Toyota SR5 X-tra Cab, SAS, 4.3 Vortec, 42" Swampers, 5.29:1 gears. |
#34 (permalink) |
yeah ill probly use that but i just want to get the thing road worthy for now so i can get to school
#35 (permalink) |
i want some trail gear axles but i dont think i have the money for em now so ill probly have to use what i got for now, but could i get a price for the entire birfield axle assembly?
#36 (permalink) |
Staff
are you asking for a quote for the dirty 30s and hub gears?
__________________
#37 (permalink) |
yes? maby, i want axles and birfields, whats a dirty 30
#38 (permalink) |
i think i just need the dirty 30's (i looked it up)
#39 (permalink) |
its back in, no blocks |
#40 (permalink) |
old birfield
4 piston calipers and green hub indicater rear axle housing rear diff(rust) |
#41 (permalink) |
front end is copletely done
#42 (permalink) |
Looks like you've got some funky blocks going on with the rear too... any better shots of that?
If it's square tubing, you may be in for some trouble
__________________
________________________________ | |---------|-------------|---------| | | |----------|--TOYOTA---|----------| | | |-----------|-------------|----V6----| | _____________________________________________
||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / \ / || ||\ / \ / ||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / TOYOTA / \ || ||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / \ / || ||\ / \ / ||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / \ / ||/ \ / \ || |
#43 (permalink) |
#44 (permalink) |
whats wrong with square tubing?
#45 (permalink) |
that part in the axle housing. do i need it, whats it do? i accidently put the diff in w/o it and waas wondering if i had to take the diff back out |
#46 (permalink) |
Not that there's anything necessarily "wrong" with it, just that if you are going to go with blocks (key part there being the word: blocks) you would figure that It would be done with a... block?
Not to be ragging on you at all, I know you bought it the way that it is, and it's very good to see you turning it around.
__________________
#47 (permalink) |
alright
![]() just hoping there wasnt another thing to fix on it |
#48 (permalink) |
I would.
Blocks are okay, but they promote axle wrap, often shoot out, or even break. Square tubing will not be as strong as a block, and honestly I wouldn't use it (square tubing) unless it was on a trail only rig. Lift springs are the best way to go.
__________________
||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / \ / || ||\ / \ / ||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / TOYOTA / \ || ||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / \ / || ||\ / \ / ||/ \ / \ ||\ / \ / ||/ \ / \ ||\ / \ / ||/ \ / \ || Last edited by shaw_j; 08-21-2009 at 02:27 PM. |
#49 (permalink) |
yeah
ill get lift springs in the future sometime |
#50 (permalink) |
hey bro, truck looks great, im stationed here at fort lewis, wa myself, send me a message sometime, interested in some new places to offroad, mostly been playin around off exit 116 old nisqually, off mounts rd.. cops arent having it anymore though, heard about a place called Elby hills offroad park, been there?
| Tags |
| 81, front, leafsprings, pre, rear, small, truck, yota |
