81 Longbed Build up (Slow)
#221
Okay so I got really bored and would like a 4x4 again so I decided I would make one out of the parts I have. So I had made a trailer out of the frame, but a little metal can fix that. Just need to find a front axle.
#222
please just go buy a beater for $500. I don't know if a first time custom frame built from scratch lying around is safe for people on the road, or worth the time for that matter
#223
Got my axle
#224
this is pretty epic,from starting to end.....great determination indeed.
cant wait to see what you come up with next.
its like junkyard wars.....i love it!
#225
Got the thing rolling today, more or less.
#228
Sounds like a popular welder. I have a Miller 211 with solid wire and 25/75 mix shielding gas. If you're in-doors I think you'll like the gas and solid wire better. I'll agree with the flux outside though.
#229
So I decided it would cost to much to piece it together, so I picked up a 1980 4x4. Ill just resale the axle. I really like the pickup I have never seen the color scheme on this one, I'm wondering if its stock.
#233
hows she drive and run?
Any plans for this one?
I was digging the custom frame build but this one is cool too..
Here it is before cleaning.
Started cleaning up the engine bay.
This will be for the onboard air.
#234
I have a brand new alterntor that i'll be gettin rid of when the om617 goes in, if thats the problem. Maybe I can help out. Only bad thing is im not sure when the om617 will be ready
#235
I don't think I have anything to say that hasn't already been said. All I know is that I'm loving your build and can't go another second without subscribing. It's awesome!
#236
So I did a compression test on the engine, not the best in the world but it will do for now, numbers were 175, 130, 155, 167. Also fixed the clutch problem. That being the PO had a weird short slave cylinder so it took pumping of the clutch to get it so it would shift, it was pretty ghetto with pipe fittings and all. Just replaced with stock and its good to go.
As far as the charging system, I haven't had time to look into it much. Though It has a brand new alternator installed on it so I would assume that the non-charging situation would be caused by the voltage regulator. We shall see, although I might just switch it out for a chevy one wire.
So the truck has a newer G series transmission so I will need to change out the drive shaft for a shorter one. Might as well change out the companion flange on the differential for a newer one at that time. Does anyone know what to torque the nut to on the flange? I read somewhere to torque it to 87ft/lbs.
Made some cheap block off plates.
#237
So I found some sweet speed holes in the bed.
Built a quick bracket to mount a CS130 up and away from the water, added bonus of not having to deal with the external regulator and gaining a lot more amperage
kawazx636
07-03-2023 03:03 AM
1uzRunner
63
11-10-2018 03:58 PM
potatopants
09-15-2015 06:26 AM
