Pre 84 Trucks 1st gen pickups
81 22R Do I put the head gasket on dry?
Old 02-22-2012, 08:51 PM
uglymudder's Avatar
I swore I read that 81 22r's had a single row chain and a plastic guide...mine is double and metal. Also, the top of my pistons have a raised rim with a recess in the center, like a pool. Anyone familiar with this setup? Oh, it's a california model, if that makes a difference. I'll post pics as soon as I figure out how. The question now, do I slap the head gasket on dry, or do I put a bead of head gasket sealant around the rim?
Last edited by waskillywabbit; 02-23-2012 at 05:28 AM. Reason: Please use relevant titles to what you're asking
Old 02-22-2012, 09:59 PM
Rollz79's Avatar
If I recall right the 22r had dual row chains till 82.
Old 02-22-2012, 10:07 PM
toyota4x4907's Avatar
81 should have been the last year with dual row chains, IIRC.
The piston tops sound right.
This is out of a -'90s 22re:
Old 02-23-2012, 05:21 AM
LoveThemYotas's Avatar
81 has a dual row timing chain with metal guides, yes use a small bead of great stuff of orange high temp gasket maker on each side of the gasket, finger tighten the bolts till the gasket maker slightly pushes out the sides them stop and let it sit for an hour or more, them go back and torque the bolts down in a 3 stage crisscross pattern. Hope this helps
Old 02-23-2012, 06:54 AM
uglymudder's Avatar
Talking
Mine are slightly different...but that dual row chain makes me happier than a 12 point buck in a bulletproof vest!
Attached Thumbnails 81 22R Do I put the head gasket on dry?-1329975847918.jpg
Old 02-23-2012, 06:02 PM
dirtdobberoffroad's Avatar
my 82 is dual row with those pistons.^
Old 02-24-2012, 07:33 AM
1stgenboy's Avatar
Head gasket goes on dry! with the exception of two small beads where the timing cover/block/head intersect. Again, the head gasket goes on dry!!! Everything else sounds right.
1stgenboy
Old 02-24-2012, 07:47 AM
snobdds's Avatar
Don't do this to the gasket, you will never get it to seal...
1stgenboy
This is the correct information...
Old 02-24-2012, 09:36 AM
rustfarmer's Avatar
Please note that Supra head gaskets are known for leaking (the stock ones) and most builders use metal gaskets to replace the stock ones. They all claim the most important factor is preventing future failures is to clean head and block surfaces really well and if possible have the surfaces honed or finished to a particular size grit. I forget the exact # but 30 seems to be the number but this is not 30 grit as in sandpaper but rather a machinist #. I can look this up if anyone wishes, or you can find the info at "supramania". I realize these are different engines, but the same principle should apply. Also, any performance engine should always recieve new head bolts or studs, best IMHO are ARP brand.
Old 02-26-2012, 09:34 AM
ConSeann3ry's Avatar
If anything you can spray them with a light coat of Permatex Copper but most are meant to go on dry.
bigjstang
08-25-2021 12:41 AM
Colington
03-08-2020 09:51 AM
smiley52
07-11-2015 05:16 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: 81 22R Do I put the head gasket on dry?
