Pre 84 Trucks 1st gen pickups
7.5 carriers
Old 11-09-2007, 03:18 PM
AE86GTS's Avatar
7.5 carriers
so are the 2wd carriers all the same
I have a 80 supra with 7.5 ring gear carrier can i use 2wd carriers on the supra rear end? Or just the ring gear and center section?
Old 11-09-2007, 03:28 PM
slacker's Avatar
2wd's are 8" .. but a different bolt pattern then the 4WD .
it'll only work on an IFS front , and then thats only with lots of work .
Old 11-09-2007, 03:41 PM
MudHippy's Avatar
2WD what? Pickups? They aren't 8". They use the same 7.5" differential as in supras and IFS fronts. Meaning all the internal parts ARE interchangeable between all 3. Ring & Pinion, side gears/spider gears, carriers(not housings though if that's you mean by "carrier"). So yeah, you could use most of the parts from an IFS differential or a 2WD differential in a supra 7.5" axle.
Old 11-09-2007, 04:03 PM
slacker's Avatar
Posts: 666 devil made me do it ... your right .. i'm wrong .. brain fart .
Old 11-09-2007, 05:13 PM
AE86GTS's Avatar
sweet now i got a way to find a cheap 410 gear!
TheBFA
02-15-2020 06:55 AM
Redeth005
06-28-2018 08:16 PM
live4soccer7
05-11-2016 06:52 PM
83yotastockR
11
11-10-2015 06:54 AM
Quick Reply: 7.5 carriers
