22r to 22re swap - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-24-2006, 05:46 PM   #1 (permalink)
JerryD's Avatar
Question 22r to 22re swap
Ok, first of all I have searched this forum and a few others. My situation is that I have an '83 with no motor in it, and a rebuilt 22re. I also have an '89 parts truck that I was planning on getting on getting the EFI stuff from. I know I will need the wiring harness, ECU, tank with EFI pump, and the fuel lines. All the other posts I have read on the subject are for swapping parts from a 22re to a 22r. I just need help to figure out what I need to swap the whole 22re in. Any help, info, or points in the right direction would be greatly appreciated. Also, has anybody used the harness from Off-Road Solutions for this swap, or heard of people doing it? Thanks in advance.
JerryD is offline
Old 01-24-2006, 05:58 PM   #2 (permalink)
EWAYota's Avatar
Send a message via AIM to EWAYota Send a message via MSN to EWAYota
http://www.tacomaterritory.com/forum...506#post270506
or put the 22r on propane and your set!
__________________
DJ
1994 Pickup
22RE, Engnbldr 261 cam, 5 speed. Tires that go around and around...
Preping for SAS......
Originally Posted By Fustercluck
"Proof that Gangus did not spontaneously generate....he has relatives."
Originally Posted By Tacoclimber
"My two year old better get a job, soon..."
Reply Posted By Oly884
"I hear coal mining is a great career."
Myspace
EWAYota is offline
Old 01-27-2006, 05:45 AM   #3 (permalink)
JuttyShabango's Avatar
Quote:
I'm doing the exact same thing right now and putting a fresh 95 22re in my FTOY.
You'll need the harnes, ECU, Gas tank (you can go external pump here with regulator if your planning a fuel cell) Your filter should be mounted on the side of the motor under the EFI stuff. So that helps.
You need the ignitor for it and you should be set. Of course plumbing. The 22r radiator is smaller in size than the later EFI radiators. Now, not sure if this would cause a problem but if your running hot you'll know why. I'm switching to aftermarket.
HTH, Also, the best place to look for details on this is the Pirate Toyota Forum FAQ.
good luck,
JuttyShabango is offline
Old 02-19-2006, 11:13 AM   #4 (permalink)
Staff
Tofer's Avatar
Send a message via ICQ to Tofer Send a message via AIM to Tofer Send a message via MSN to Tofer Send a message via Yahoo to Tofer
Quote:
how does one do that?
__________________
94 4runenr: all the good stuff.......
89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs.
81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s
pacific-crawlers.com
For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :)
Tofer is offline
Tags
22fr, 22r, 22re, 8788, automatic, compatibility, forum, forums, gas, manual, radiator, swap, swapping, tank, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rebuild or 22R to 22RE swap? GreeneHoosier 95.5-2004 Tacomas & 96-2002 4Runners 10 08-17-2005 08:08 AM
22r/22re swap running poorly Twisted4runner 95.5-2004 Tacomas & 96-2002 4Runners 6 05-20-2004 11:28 AM
22RE and 22R Head swap...compatible years? Mudd Runna 95.5-2004 Tacomas & 96-2002 4Runners 5 04-13-2003 06:53 PM
22R to 22RE swap markhodges 95.5-2004 Tacomas & 96-2002 4Runners 1 10-23-2002 10:16 PM
2009 InternetBrands, Inc.
