1981 Toyota 4x4 dash modification - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-30-2009, 12:48 PM   #1 (permalink)
I am wanting to put in a older model Nakamichi pull out stereo into my 1981 4x4 truck. I know some mods. will have to be done. I currently have a stock stereo and the stock cassette right above it. I will be having to cut the plastic dash. What is the best way to do this?
russtri is offline
Old 09-30-2009, 01:07 PM   #2 (permalink)
a small cut off tool, such as a dremel, will be the best for the plastic...you may have to cut some supports out behind the dash panel to fit the width.
__________________
81 4WD Flat Bed
yota81 is offline
Old 09-30-2009, 02:16 PM   #3 (permalink)
tj884Rdlx's Avatar
if you haven't cut plastic with a dremel, you don't know what you're missing. i've done a lot of stereo installs using razor knifes, hacksaw blades with tape around one end, etc. a dremel goes through plastic like butter if you crank up the rpms and let the cutting wheel do the work. be prepared tho, hot liquid plastic will spray and burn mildly. it's irritating.
HOWEVER, i just looked at a picture of a dashboard for an 81 for sale on fleabay. the pic shows a radio on bottom and a pocket above. are you sure the pocket above isn't a DIN size hole? you may be able to pull that cassette and its brackets, and mount the sleeve for the pullout nakamichi right in that hole without cutting. check it out first. it might require just some filing of the hole to fit the sleeve, instead of major cutting. and then you can leave the factory radio alone.
__________________
88 4Runner DLX, 15x8 soft8s w/ BFG 33x10.5 A/Ts. 1.5" SDORI spacers, OME CS009s, 1" 4crawler b.l., original Canback top
tj884Rdlx is offline
Old 09-30-2009, 04:02 PM   #4 (permalink)
rowdy235's Avatar
You may not want to hear this, but....
Stock Umolested Center Bezels are getting more and more rare as time goes on. My truck, for instance, doesn't even have the original one, its cut from a piece of plexiglass.
Now, if it were me, I would remove the whole bezel, and put it some chrome diamond plate or something like that, would make it look way cooler, plus for the price you could get out of the bezel, you could probably pay for the diamond plate.
That said, a dremel does work great for cutting plastic.
__________________
The Daily Driver:
1998 Tacoma | Regular Cab | 4WD | 2.7L | 5-Speed Stick | Mostly Stock
The People-Hauler
1988 Grand Wagoneer | SUV | 4WD | AMC 360 | 3-Speed Auto | All Stock
The Dump Runner
1982 Pickup | Regular Cab | 2WD | 22R | 5-Speed Stick | Custom Exhaust
FER SALE! http://www.yotatech.com/f108/1982-sh.../#post51229916
rowdy235 is offline
Old 10-01-2009, 05:14 PM   #5 (permalink)
^ this is true. modifying the stock bezel for a new cd player leaves it looking messy, and the supports behind have to be cut out. sell the original dash and make a new one. probably make enough money with the sell to make whatever you want.
__________________
81 4WD Flat Bed
yota81 is offline
Old 10-01-2009, 06:01 PM   #6 (permalink)
slacker's Avatar
true dat !!!
If your dash is in great condition .. the DONT CUT IT !!
there are tones avalable at the wreckers .. so go get one of those , and keep the original in good shape .
if it's already been "hacked" up .. then cut away
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come .
84 2WD "hotrod" Intercooled 7MGTE
83 Trekker SR5 CURRENT BUILD
My home page MY PAGE
2WD fourm I frequent
NEW Trekker forum
slacker is offline
Old 10-02-2009, 03:12 PM   #7 (permalink)
Sked's Avatar
How much would you guys pay for a mint dash and pad anyways? They are rare as crap around here not even a single toyota older than 85 in any wreckers.
I drove up north to Mackenzie and picked up a parts truck and it had a mint pad and dash... couldnt believe it and paid 300bux
__________________
81 shortbed 4" Lift, 4.37 w/ Lockright Rear, Bilstein 5150's, Custom bumpers w/Ramsey8000 and flatbed
20r bored .060 w/ wiseco 9.9:1 forged pistons, Weber 38 outlaw
260 Comp Cam .440lift ,Crane Springs, 22r Valves, Pacesetter Header with a Flowmaster 40
Sked is offline
Old 10-02-2009, 05:36 PM   #8 (permalink)
slacker's Avatar
I might be interested ...
email me cj@toyotafiberglass.com
__________________
NEW Trekker forum
slacker is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
