1980 power steering?
hey i got a 1980 4x4 20r .no power steering .i want to add power steering .how would i go about doing this and what parts do i need?just need a idea of how to do this thanks yalll
I believe u need a power steering box but maybe you can just tap the one you have already. Of course you need the pump,lines and all that bull as well. You could buy an aftermarket pump and all that but you can also go to junkyard and pull one off a 22r (79-85)? i haven't done the swap so you should get other imput from other sources. try searching. there is no electrical or vaccum lines for these pumps so it should just bolt up and work.
ive tried searching if anyone knows a site that might have it let me know ..where would this bolt up or would i have to make brackets ??actually i dont have a clue where to start haha
When I put p/s on my 81 22R, I pulled the system from an 82. I got the steering box, pump, pressure line from pump to steering box, return line to reservoir, cooler lines/cooler tubing that mounts behind the grille, pump mounting bracket and belt tensioner. The only thing I didn't get was the crank pulley, as it is wider than stock pulley without p/s.
delmert
09-30-2015 04:34 PM
