Pre 84 Trucks 1st gen pickups
1/2 ton runningh gear under 83 pick up please help
Old Dec 13, 2007 | 08:28 AM
frank_claytor's Avatar
i have an 83 toyota pickup with 9 inches off lift and i want to do all chevy running gear got a hole chevy truck for parts its complete need to know how to fit up and line up 1/2 ton running gear and whats needed thanks
Old Dec 13, 2007 | 08:36 AM
dropzone's Avatar
Fossilized
Sounds like a cool project and a ton of work...
I would suggest that you check out this forum: http://www.pirate4x4.com/forum/forumdisplay.php?f=12
I think that you might be able to find some of your answers there as Pirate is more into that sort of mods...Good luck
Old Dec 13, 2007 | 08:58 AM
Greg_Canada's Avatar
I wouldnt bother with 1/2 ton running gear, as the stock toyota parts are as strong as a d44.
If you want to upgrade either beef up the yota' axles or get dana 60/ford 9"...
Old Dec 13, 2007 | 04:10 PM
Kinda Like The Wide Look Any Body Got Any Pictures
Old Dec 13, 2007 | 04:19 PM
bigarms23's Avatar
basically its the same asa doing a sas on a toyota all you really need is skymanufacturings front hanger. for mine that i did i am using toyota leafs and toyota dual cases and the rest is chevy
Old Dec 13, 2007 | 04:28 PM
New To All This Could U Explain It Please Do U Have Any Pictures Did U Narrow The Chaevy Stuff
Old Dec 14, 2007 | 08:31 PM
bigarms23's Avatar
sorry i dont have any pics basically i left the chevy axles uncut i also like the wide look. when i did my swap i used skymanufacturings toyota full width kit
I have 5inch toyota springsf&r than i used chevy u-bolts. i also invested in a set of crane high steer knuckles for the front axle that way it fixes the weak chevy knuckes. i did have to take and have brake lines made than i up graded to a chevy brake booster and master clinder and a wilwood proportioning valve cause i am running a set of 36s
Old Dec 14, 2007 | 08:36 PM
EWAYota's Avatar
where you located? If your going to pull your toyota gear out, people on here would take it, at least the front axle. First dibs though if your within 100 miles of me which your probably not.
Old Dec 15, 2007 | 01:37 PM
Island_Yota's Avatar
I wouldnt bother, Why not just buy a Chev instead? save alot less work, this is coming from a guy that hates the wide/fullsize running gear look though.
Old Dec 16, 2007 | 08:10 PM
bigarms23's Avatar
like i said go head and do the chevy swap if you has questions pm me and i will help you
Old Dec 17, 2007 | 03:34 AM
thanks
Old Dec 23, 2007 | 12:12 PM
bigarms23's Avatar
what i forgot to mention was the cool part of full width axles is you can run a 3inch lift and run 39.5inch tires
Old Dec 25, 2007 | 11:26 AM
4banginRunner's Avatar
these guys have a kit for full width sas
http://www.sky-manufacturing.com/
the1998sr5
15
Jul 14, 2020 08:35 PM
XtraCab
Apr 12, 2020 05:25 AM
oldirtydirt
Feb 23, 2020 09:30 AM
mskalmus
May 28, 2017 07:51 AM
skoti89
Jul 6, 2015 07:45 PM
