MASS CLEAN UP ToYoTa PaRts Galore michigan
Located in michigan
Most all prices are Shipped.
I do paypal unless your special.
More stuff added at bottom of page
IF you do not see something you need just ask me I might have it
89 Dual booster Diaphragm 40 Plus shipping
89 master cylinder 30 shipped OR BOTH for 75 shipped
Also a single diaphragm from a 86 4runner with MC 40 - 50 shipped
4 CYL gear housing minus carrier 60 shipped
Birfields 100 shipped
89 under dash plastic 30 shipped
89 clutch switch 15 shipped
2wd trans 120 shipped or will tear apart for part out
86 4runner clutch and brake bracket NOT BROKEN 50 shipped
86 4runner air tube 40 shipped
4runner or truck mirror no light 25 shipped
86 IFS drive shaft NEED TO BE GROUND will cut up and ship in flat rate box for 50 shipped
86 non tach instrument cluster Works great 50 shipped
I have 4 sets of front calipers
make offer
89 engine wire harness single cab 75 shipped
89 arm rest 15 shipped
IFS calipers need cleaned 30 shipped
89 single cab 22re ecu 80 shipped
89 power steering Res 25 shipped
make offer
89 single cab engine coolant res 30 shipped
89 multi switch works perfect 45 shipped
set of IFS wheel hubs 50 shipped for two
89 throttle body 22re efi
89 injector rail with only TWO injectors and cold start injector 50 shipped
KX 89 4x4 single cab 22re ignitor and coil 70 shipped
I want those 4Runner plastics if purchaser flakes! Do you do PayPal?
My compliments on a very thorough part out and great pictures.
More stuff to add for sale:
w56 shifter 40 shipped OBO
84-88 and 89 in 4runners Side kick panel 25 shipped
89 single cab dash trim 35 - 45 shipped depends on how far away you are
4runner tail lights and I do have both from blinkers 50 shipped
s12w brake calipers 45 shipped
old rockers 20 shipped ?????
slightly used osk timing kit with all the stuff 30 shipped
89 dash. not perfect but better than nothing PM for pricing
89 22re in dash wiring harness 75 shipped
steering wheel cover that says toyota 25 shipped
