81 longbed 4wd solid axle project+ parts
Old Oct 24, 2007 | 10:34 AM
skullver's Avatar
first $800 cash takes it all away, come and get it, Ventura, CA, 93001
for sale, I do have the original title from the previous owner(I never did the transfer to my name), has CA back registration and probably could be registered for not too much hassle, it has a ghetto fab solid front axle swap that is not complete, 22r runs fine, 4wd(5-speed) tranny won't shift into gear, may be linkage problem but I really don't want to mess with it any more, it will come with most of the original 2wd ifs stuff and original 2wd(also 5-speed) tranny that worked fine but slipped out of 2nd gear, no tranny expert here as you can probably tell. Tires are 31-11.50-15 Mickey T bajas with 75% tread on 3 centerline 15x10 and one knock-off. The front rear shackle hangar needs to be re-done, steering is ghetto at best but worked fine to push around the shop, alot of the work should be re-done right. Wouldn't take a capable fabricator much to get it finished up suspension wise, it is in Ventura(93001) CA, and will need to be towed away. First $800 cash takes it all away. Transfer case seems to shift fine, has a custom front driveshaft(coast driveline) and the rear is stock from 82 shortbed so will need to be lengthened, has bolt-on axle trusses front and rear, feel free to ask any questions, I am really no yota expert or even close so I'll try to answer any questions. chrisculver@culverequipment.com
will need to be fixed along with steering:shaking::
Old Oct 28, 2007 | 03:00 PM
skullver's Avatar
Sold
SOLD and gone, thanks for looking
MMA_Alex
25
Apr 18, 2017 05:07 AM
ItsJustD
Jul 7, 2015 07:49 AM
toyoda8488
Jul 5, 2015 10:18 PM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
