Engines - Transmissions Place above type items here
FS[NorAtl]: FS: NYC 1987 4x4 22RE Engine and Auto Trans
Old 09-20-2015, 06:08 PM
TransAmBandit's Avatar
Up for sale is the engine out of my 1987 Toyota 4x4. Motor is still in the truck at this moment.
Engine runs but it has a misfire due to no compression in the number three cylinder. Engine has 126k miles on it. It was an original owner truck that was parked for a few years. I've only owned the truck for two months so I can't tell you much on the life of it. I bought it with the issue. The motor is a good candidate for a complete rebuild or swap into another chassis. It's a rear sump motor.
I can demo the engine and take a deposit before I pull the motor.
The motor will come as a package:
Engine
ECU and harness
Ignitor, injector resistor
All engine belt driven accessories
I will also have the automatic transmission for sale with transfer case. I don't know much about the transmission either. Other than it worked to move the truck and that one of the cooler lines had a hole in it from rust. Will need the line replaced or repaired with a cooler hose. Not a huge issue but I would like to mention it.
Asking $200 for the engine and $100 for the Transmission.
Call or text any questions
347-223-6878 -Sam
Attached Thumbnails FS: NYC 1987 4x4 22RE Engine and Auto Trans-image.jpg
vasinvictor
01-20-2016 12:39 PM
BLRobertson
3.4 Swaps
07-10-2015 04:27 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: FS[NorAtl]: FS: NYC 1987 4x4 22RE Engine and Auto Trans
