Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Torque Wrench?
Old Jan 12, 2007 | 11:34 AM
davemacneil's Avatar
Torque Wrench?
Should i go with the larger 1/2"? Girlfriend is getting me a present and i want to get something that I can't pull myself to buy. I will prob be doing an engine rebuild in the spring or summer.
3/8"-drive torque wrench, with 25 - 250 lb. torque setting
1/2"-drive torque wrench, with 30 - 250 lb. torque setting
Lifetime manufacturer's warranty
Old Jan 12, 2007 | 11:40 AM
mastacox's Avatar
Go with 1/2" drive, since most bolts that have torque requirements in that area will require a 1/2" drive socket anyway, and you can use a 1/2"-3/8" adapter if need be.
Old Jan 12, 2007 | 11:54 AM
thats my thoughts, thanks, always a good idea to double check when it only takes a second. thanks YT
Old Jan 12, 2007 | 11:58 AM
waskillywabbit's Avatar
Get a small setting one too, as a lot of bolts take 25 ft-lbs or LESS.
Old Jan 12, 2007 | 12:00 PM
mastacox's Avatar
If you want a 3/8" torque wrench, make sure it handles much lower torques, like 1-50 ft-lb... I need to get me one of them as my Craftsman 1/2" TW only goes down to 25...
Old Jan 12, 2007 | 12:50 PM
Jacket's Avatar
Yea - you really need one of each. I've got a 3/8" that goes from 20-100, and a 1/2" adapter that I use as needed. But I wish I had a 3/8" that covered torque's from 5-20 or more, and then a bigger 1/2" for the larger jobs.
Old Jan 12, 2007 | 02:16 PM
AxleIke's Avatar
I will second one of each. I have 4. One that does upwards of 350. One that does the 25 to 150. One that is like 5 to 70. One that does inch lbs, for gear instals.
Kamaloha
Oct 16, 2015 05:13 PM
JUICE222
Oct 13, 2015 08:50 AM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
Pocoyota
Sep 8, 2015 02:41 PM
