YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-18-2007, 07:55 AM   #1 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
Need a new torque wrench
I have one similar to this Craftsman unit.
However mine only goes up to 75 ft lb, and I need one to go higher to tighten the Toyota lugs properly.
Mine goes up to 75.
Reading the reviews on the one above, that model does not look promissing, and the plastic collar breaks after awhile.
Some of their other wrenches command up to $600.
What have you used successfully without any breakage of the wrench?
__________________
Corey
2007 FJ Cruiser
ARB bumper, Warn XD9000, OME lift, roof top tent, so much more, see my website & buildup thread
PNW FJ CruisersDetailing 101Join TopsitesMuffler ComparisonsMaggiolinas In The Wild
FJ Cruiser BuildupNew Roof Top TentVideo Of My PenthouseRehinge Your ARB/Engel Fridge
Corey is offline
Sponsored Links
To remove this ad, register today!
Old 08-18-2007, 02:01 PM   #2 (permalink)
Staff
Corey's Avatar
After reading up further on the Craftsman one, I refuse to buy it.
Many of the reviewers posted stating that is was shameful for Sears to even have the Craftsman name on it, and only a one year warranty.
So what am I to do?
Why not go to the source that uses torque wrenches on a daily basis?
I called up my local Les Schwab Tire Center and they use Armstrong torque wrenches there.
My contact ordered me a 25-250 ft lb model, same one they used a few weeks back on my rig when I got the new tires/wheels installed.
It should be here Tuesday.
The model # he gave me is not coming up on a web search, but it may have changed.
And Armstrongs website is not loading for me right now.
But a search for wrenches brought up this model that may be it or similar.
http://www.toolsource.com/micrometer...d-p-98199.html
Although the lower price of the Sears one is great, having the plastic handle break later on is not.
Best to spend a little more now and get something that will work when you need it.
I will update this thread when I get the actual unit.
A tip from the guy at Schwab, always put the wrench back to zero ft lb when done to take the tension off of it.
__________________
Corey
2007 FJ Cruiser
Corey is offline
Old 08-18-2007, 02:48 PM   #3 (permalink)
BT17R's Avatar
Corey, I've used the one below for the past 30 years. I get it calibrated about every 10 years and it's always spot on. During road racing season I use it to check wheels 4X each race day for twenty events per year. I've never checked reviews, and just now found out what it cost (it was a gift). Seems decent for the price:
http://www.drillspot.com/products/13...que-Wrench?s=1
__________________
'07 FJ TRD SE 6M/T 100% Black
'09 4R SR5 TE 5A/T Shadow Mica--Inbound
BT17R is offline
Old 08-18-2007, 02:57 PM   #4 (permalink)
Staff
Yoda's Avatar
Hey Corey,
In my work I use torque wrenches from 25 inch lbs to 600 foot lbs.
I buy my snap-on ones on EBAY. The micrometer style does need to be turned down to minimun when stored. The breaking beam style does not. I like the flex head instead of fixed.
RANT ON!
(My local "tire store" runs them down with impact, then uses a torque wrench. The wrench just clicked, didn't rotate the nut at all. They said it was 100, I showed them they were at 175. The nut HAS to turn before it clicks or it is too tight!)
END RANT
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 08-18-2007, 03:14 PM   #5 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
I have a Craftsman 1/2 and 3/8 drive and they both work fine. I got them on sale for under $100.
waskillywabbit is online now
Old 08-18-2007, 03:18 PM   #6 (permalink)
Staff
Corey's Avatar
Hey Bob, that one looks similar to the one LS ordered for me.
Dave, my local LS store will use an impact wrench on regular wheels, but if they see someone has aftermarket wheels such as mine, they will do it by hand.
One reason I have dealt with this shop since 1991.
I think the one I am getting has a flex head.
I saw them a few weeks back use it when they put my Gorilla locks on.
Brian, yours are probably similar to the old one I have that goes to 75 ft lb.
Never had a problem with it, and will use it for other stuff, but I have to go new since it does not go high enough.
I hope yours does not break like in the reviews I have been reading.
One reviewer had a cure, but it would have to be implemented from the factory.
__________________
Corey
2007 FJ Cruiser
Corey is offline
Old 08-18-2007, 03:24 PM   #7 (permalink)
frodin1's Avatar
I'm actually in the market for a new one. I had company issued ones for the past number of years, both of which were Proto I believe and were nice. I noticed Sears had there regular ones on sale last month in the mailer, and now they have the digital one on sale. I'm really not to sure about either. And Purchasing online used ?Has anybody had to send these in to be recalibrated or anything?
__________________
Pioneer HU, Audiobahn 10.100watt Sub, Sirius, Cobra NWWXST CB W/ K40, Wolo Air horn, K&N FIPK,Tokico Trekmasters,Tundra TRDs, Revtec spacers w/extended studs,Energy bushings on steering rack /front swaybar,SS front diff. drop kit w/skid plate mod,OME 890 Rears with OEM LC Tokicos,Ebrake ext. bracket, BFG AT/KO's, ProComp 1078 Alloys, Magnaflow SS muffler, Hayden 1678 Tranny Cooler, 85watt Amber fogs, 7 Way R/V plugin.
frodin1 is offline
Old 08-18-2007, 03:28 PM   #8 (permalink)
Staff
Corey's Avatar
Proto was another brand the sales guy at Les Schwab mentioned to me today.
He said they were good.
__________________
Corey
2007 FJ Cruiser
Corey is offline
Old 08-18-2007, 03:40 PM   #9 (permalink)
frodin1's Avatar
Yea, I have no complaints. It's just the cost factor. You might as well buy a snap-on or other name brand. They all fall into a certain price range if you want quality. Ebay has a ton of snap on ones for sale, I'm just unsure about them being screwed up from not being taken care of.
__________________
frodin1 is offline
Old 08-18-2007, 04:25 PM   #10 (permalink)
Staff
Yoda's Avatar
I only buy the snap-on ones on EBAY that look good (not beat/rusty) I try no get the newest one listed (I think the part # ended with a, b, c, etc).
When my work used to check the personal ones, it was good. They don't do that now.
__________________
David
TLCA 14788
Yoda is offline
Old 08-18-2007, 04:48 PM   #11 (permalink)
111db's Avatar
Send a message via MSN to 111db
When I worked for United Airlines their torque wrenches were top notch and calibrated every 30 or 60 days, if I recall correctly.
But for auto use, that level of precision is not required.
Believe it or not I've been using a Harbor Freight TW at home for about 5 years now. I think its a Pittsburgh. Its a 3/8" and goes from 20-100ft/lbs. Been thinking about a smaller in/lb and larger as well. No complaints considering its an import. Something to consider if you aren't using one every day.
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 08-18-2007, 05:31 PM   #12 (permalink)
CJM
CJM's Avatar
Really all you need is a tire iron, you can easily torque the wheels on by hand. I actually tightened mine on with a 4 way iron and checked with a torque wrench, 90ftlbs and I barely tried.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 08-18-2007, 05:45 PM   #13 (permalink)
frodin1's Avatar
I need them for other things also. Infact I had to borrow one just a few weeks ago to torque the nuts on my steering rack "new bushings". It's one of those tools that fall into that catagory of " If you need to borrow it more than twice you might as well buy it"!
__________________
frodin1 is offline
Old 08-18-2007, 05:50 PM   #14 (permalink)
CJM
CJM's Avatar
Generally its a good idea to have an inch and ft torque wrench, I would buy harbor freight pittsburg as they arent half bad and the amount of use they see is worth the small cost.
Could always have them calibrated but my friend has had good luck and they arent off by maybe 1/2 a pound at most which isnt a big deal (ftlbs one).
__________________
CJM is offline
Old 08-18-2007, 07:44 PM   #15 (permalink)
ewong's Avatar
After having a Craftsman torque wrench get wonky on me (clicks at 70lbs but when I turn it up to 75lbs it put another 360 degrees on the nut w/o clicking - oops)
I just shelled out for a SnapOn...
ewong is offline
Old 08-19-2007, 02:23 AM   #16 (permalink)
86tuning's Avatar
The split-beam type torque wrenches made by Precision are the same ones that Snap-On sells. Very well priced for a quality instrument.
I have the 50-250# flex head one, and it cost me around $250 when I bought it years ago.
__________________
- Brian
86tuning is offline
Old 08-19-2007, 09:08 AM   #17 (permalink)
FyrHazard's Avatar
I got the 250 ft.lb craftsman several months ago.
http://www.sears.com/sr/javasr/produ...BVCookie=Y es
It is much higher build quality than the one listed in the first post for only a little more. So far I've been really happy with it.
Hmm just read reviews on their site and it appears some had a lot of trouble with it. I haven't noticed any of these problems yet, but I guess we'll see.
__________________
Jeff
"Slow is Smooth; Smooth is Fast" - Shooter
FyrHazard is offline
Old 08-19-2007, 09:37 AM   #18 (permalink)
Staff
Corey's Avatar
I have seen the beam types with a huge dial, those turn me off, but what is this split beam stuff?
I saw a few listed in yesterdays search, but did not check into them.
The one you posted almost looks like it has a digital readout.
If so, that is radical.
I am still going for the one Les Schwab ordered for me, but it never hurts to have two
One will stay in the rig, and one in the home tool box.
A man can never have enough tools.
Fyr, yeah, it is the way the handle is designed on the Craftsman's that is causing the breakage, then the handle free spins.
This is why I am looking into a different make this time.
Otherwise I would be all over it since most of my tools are Craftsman.
__________________
Corey
2007 FJ Cruiser
Corey is offline
Old 08-20-2007, 04:59 PM   #19 (permalink)
Staff
Corey's Avatar
Armstrong's page is back up.
http://armstrongtools.com/catalog/pr...sp?groupID=910
It is the 25 to 250 model.
Should be ready for me to pick up tomorrow.
__________________
Corey
2007 FJ Cruiser
Corey is offline
