Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Jack & Jack Stands
Old 10-30-2005, 06:00 PM
Gangus2006's Avatar
Originally Posted by Gangus2006
Would a 3000lb floor jack work for a 4Runner? Ive been looking high and low for Aluminum Race Jacks to keep int he back of the 4Runner, and the only one I can find is a 3000lb jack from Sears.
Reason: Dont want anything heavy back there, but really dont like using the bottle jack. Ive had it slip on me on more than a few occasions (IN MY FREAKIN LEVEL DRIVEWAY), so Id really like something else.
Does anyone know for sure?
Old 10-31-2005, 11:52 AM
Snorkeldepth's Avatar
Coolest jack stands I ever saw was when I helped out at the Lake Superior Rally last year. They had steel tubing welded up in a tripod with a pin that stuck out sideways from the top. We'd just jack up the car and slip the pins into tubes that were cut off flush with the rocker panel trim . . . then lower the car onto the stands. You can kinda see two black dots near the front and back of the rocker panel trim in this photo:
http://www.libraracing.com/
Old 10-31-2005, 06:44 PM
kyle_22r's Avatar
believe it or not, but harbor freight sells a good floor jack.
Old 10-31-2005, 07:44 PM
ASU4runner's Avatar
I wouldn't trust anything less than 2 tons to lift your vehicle.. it'd most likely put too much stress on the jack.. also, jacks under 2 ton are typically not able to lift your 4runner high enough to even remove the wheels.
FYI there is a little bottle jack (˟˟˟˟˟ty but it WILL work) under your passenger side rear seat.
Old 10-31-2005, 08:48 PM
  #25
FilthyRich's Avatar
I have too much $$$$ in my Snap-On 2.5 ton floor jack. However I will never need to buy another jack ever.
I also have a pair of Blue POint 6 ton jack stands and two pairs of 3 ton Blue POint jack stands.
The nice thing about my 6ton are they lift really high. Never had an issue under the 4r and plenty of room to support a taller vehicle
Like what has been said, i believe 2.5 ton is a minumum for a floor jack
Old 11-20-2005, 09:57 PM
  #26
mach4's Avatar
The 6-ton jack stands from sears work well.
I also bought their suv 21" jack but I'm not too happy with it.
Although it has good length, it's very narrow.
I like the speedy jacks as well, and this one takes several strokes to get it to the chassis. I'm still on the fence on the jack we'll see how it keeps working.
I've only used it a couple of times.
Old 11-21-2005, 08:00 PM
  #27
aowRS's Avatar
For the last word in super high quality jack stands, take a gander here or here..
I needed stands with flat tops (with rubber pads) for the 993, as well as traditional cradle tops for the 4Runner's rear axle. I ended up with two sets of the 3000N (6,000 lb) stands with flat tops, and a pair of cradle top posts. These things are insanely stout - there is no comparison to the various cheap-o stands I've had/discarded over the years. Stability is first class and the round steel 'pads' under each leg guarantee that these will not sink into hot asphalt. Also makes sliding them across garage floors easy. Expensive, yes. But it's the last set I'll ever buy, period.
Andreas
4.34runner88
02-07-2016 02:24 AM
BK2TFUTURE
10-11-2015 08:42 PM
May-39
09-06-2015 01:05 PM
mavenator
08-13-2015 01:12 AM
Sr5crawler
07-31-2015 12:32 PM
Quick Reply: Jack & Jack Stands
