Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
ADVICE NEEDED: wiring 220V for a welder
I'm seriously considering the purchase of the Hobart Handler 210.
Here are the specs: http://www.northerntool.com/webapp/w...6866_200336866 All I need now is the 220V line. I've got an existing breaker box in the garage attic with 3 single pole, 15A breakers. All three are used. The line going into the breaker is 3 #10 AWG and it runs about 100 feet from the garage attic to the house. Can a 220V line be tapped into the box, or do I need to run another heavier gauge line from the house to the garage? Help please.... Troy
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD |
| Sponsored Links |
#2 (permalink) |
just tap into it and what ever you tap it into dont run whats connected to it for instance i rewired my welder with a bit thicker gauge wire with a new plug and just wired mine right below my breaker. I wired mine to the exsisting stove which we never use. it works great however if I do use the stove i cant weld. hope this helps
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more. Might as well start reading this if ya want know more |
#3 (permalink) |
Sponsoring Member
Find a friend who is an electrician or knows one. Guessing with that kind of voltage can burn your house down.
Do it right.![]()
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab 6th Annual South East 4Runner Jamboree, May 22-25, 2009 WabFab Off-Road Salvation Army Online Kettle |
#4 (permalink) |
ya true wabbit if your not good with electronics and such it would be in your best intrest to have it done by someone who is. My buddy helped me. his dad owns a cabinet shop and my buddy new all the laws and such and has done this kind of stuff alot of times. Be very carful always when dealing with power like that
__________________
#5 (permalink) |
yeah... this is as easy as calling an electrician...
__________________
Daily Driver: 2007 Windsor "The Hour" Fixed Gear 250 miles Crouch Rocket 2005 Felt F80 1100mi (purchased new in Jan 2008) 2006 Mazda3 GT 2000 TRD Tacoma..Bought back and crushed 1988 4Runner SR5 V6 5 speed..sold |
#6 (permalink) |
The thing to do is look @ the nameplate of the welder. What you are looking for is the FLA rating (full load amps) If I had to guess you are in the boat of 40-50 amps@220 volts. You might want to step the wire up to #8 b/c of the long length that it is, to be on the safe side. I'd call an eletrician to verify this for sure. Happy welding!
__________________
Airaid cold air kit, airaid throttle body spacer, Jardine cat-back exhaust, Alpine 9815 receiver, two pair polk momo component (mm6) speakers, two polk 12" subs (dx12) Alpine dvd changer, Alpine xm radio module, lightning audio 1.0 farad capacitor rockford fosgate (two) 250@2 punch amps, (one) rockford fosgate 200@4 for the components, all monster cable wiring for ai-net stuff+power wiring. Dynamat all over the place, Bridgestone REVO's 255/70/16 mated to 16x8 trd Ivan Stewart wheels |
#7 (permalink) |
To get 220V you'll need two separate phases of 120V current. You could try an AC volt meter to see if any of your 3 breakers are on the same phase or not. If on the same phase, you'll get essentially 0V between the hot leads of each breaker. If any are separate, you'll see 220V between the leads. If those 3 breakes are all on the same phase (likely if they are connected to the same feed wire), you'll need to go back to the main panel to get the 2nd phase.
And yes, would be a good idea to get professional help if you don't know what you are doing.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Good Welder needed in/near DE??? | Mahoney | The Fab Shop | 1 | 08-06-2007 11:43 PM |
| Colorado Springs welder needed | Swank | Off Topic Talk | 0 | 03-26-2007 07:07 AM |
| Need a little wiring advice | Kyle95sr5 | 86-95 Trucks & 4Runners | 4 | 09-17-2006 05:39 PM |
| Rewiring my FLX210’s to run off the ignition: Wiring advice needed | <96 Runner> | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 09-16-2003 08:01 PM |
| Phoenix area welder needed for Stubbs Sliderz | <96 Runner> | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 08-25-2003 07:04 AM |
