This article applies to the Toyota 4Runner, Tacoma, and Tundra (1996-present).
If the key fob to your Toyota 4Runner, Tacoma, or Tundra doesn't work the way it used to or appears to be completely non-functional, don't head down to your local Toyota dealership just yet. There are simple solutions you can do right there from your very own home, without ever needing to enlist (or pay for) the help of a professional mechanic or dealer, to fix the problem. Not all fixes can be done from home, but we've outlined the ones that can. We also explain when's a good time to make that trip to the dealership, after all.
Materials Needed
Replacement batteries
Microfiber cloth
Step 1 – Check the batteries
They might be going bad.
Before carrying out more complex troubleshooting tips, which we will explain how to do in subsequent steps, it's best to check the fob batteries for power. If they are going bad, you'll need to remove the old set and replace them with a new one.
Replacement batteries will typically cost between $2 and $5 for a set of two.
You can purchase individual and bulk sets at any local auto parts store or big box retailer.
Ensure your new batteries have a strong contact point; increased tension will improve performance.
Place the cover back onto your key fob and check the device for activity.
Figure 1. Check the fob batteries.
Pro Tip
It's also a good idea to check your fuses (see your fuse box) at this point, as well.
Step 2 – Check the receiver
It might be shorting from seasonal moisture found in the air.
The receiver is located in the lift gate of your truck and can short if it's exposed to moisture. You'll need to pull the cover off the hatch to check the receiver for water (or moisture) damage.
Try drying the receiver with a dry microfiber cloth and creating tension along the contact point inside the actual key fob before seeking outside professional assistance.
Check your key for for results.
If you need to head down to the dealer, an electrical diagnostic report will run you around $85 and, if a replacement receiver is needed, you'll be looking at another $380 plus the cost of labor.
Pro Tip
Check the box (ECU) under the driver's seat for damage, as well. Moisture can become trapped here and will need to be repaired if the damage is significant.
Figure 2. Check the ECU.
Step 3 – Have a mechanic check the door lock actuator or latch assembly
It might be malfunctioning or going bad.
If your doors unlock but won't lock with the key fob, a bad door lock actuator or latch assembly could be the culprit.
However, if the doors unlock using the door control panel, then the issue is something else and will need further troubleshooting.
If there is a beeping sound, the issue could be related to your alarm.
If your alarm is malfunctioning, tricking itself into responding to the threat that you are about to lock your key fob inside your vehicle, then you'll need to see a professional mechanic for more advanced service repair (unless you are skilled in repairing sensors).
Figure 3. Faulty rear door latch.
Step 4 – Reprogram the key fob
The factory programming might have been erased.
Occasionally, a key fob can lose its original programming and will need to be reprogrammed, which either you or a Toyota dealer can do.
Remove your key from the ignition, if it is not already.
Next, open ONLY the driver's side door (keeping it unlocked).
Insert the key into the ignition without turning it, and then remove it.
Using the door control switches, lock and unlock your doors (proceed for five passes) and do this within 40 seconds.
Close and then open the driver's side door, manually.
Within 40 seconds, lock and unlock your truck for five passes or cycles.
Turn the key on and then off in the ignition (once) to reprogram your key fob.
Remove your key from the ignition.
Your power doors will automatically lock within three seconds.
You will have 40 seconds to press and hold the "lock" and "unlock" buttons on your key fob. This should be done simultaneously and for one second.
Release both buttons, and hold the "lock" button for two seconds.
Toyota Tundra How to Program Keyless Remote
When it comes to a malfunctioning key fob, you have two main options. Read on to find out what they are.
This article applies to the ...
Toyota 4Runner Door Won't Open
Why Won't Driver Door Open?
As cool as it was when Beau and Luke Duke jumped into the General Lee through the windows, that's not something you're going to want to have to do in ...
Toyota 4Runner Why Does My Alarm Keep Going Off
Why Does My Alarm Keep Going Off?
Don't let a faulty vehicle alarm drive you nuts. Keep reading to learn how to fix this pesky problem once and for all, so your ...
Toyota 4Runner Rear Window Won't Work
Why Won't My Rear Window Work?
The 4Runner's rear window can run into all kinds of problems. Read this for the solution.
This article applies to the Toyota 4Runner ...
Toyota Tundar Installing Engine Start/Stop Button
How to Install Engine Start/Stop Button
Start your truck with the press of a button.
This article applies to the Toyota Tundra (2000-Present).
It's easy to be a ...
Toyota Tacoma Rear Cargo Hatch Won't Open
Why Won't Rear Cargo Hatch Open?
If the rear cargo door to your (1996-2015) Toyota Tacoma won't open, a number of issues could be at play. Here are our best tips for ...
