rear diff repair, need advice
What a great truck! Just picked up a '96 T100 Extra Cab 4wd automatic this weekend- 244K miles and you'd never know it. A great truck, light years ahead of the '94 F150 I had for a year. Fix Or Repair Daily is an understatement.
A few issues-
Rear diff might need service/repair. Driving down a hill at 50-60 mph, lift throttle, get a vibration in the rear. Much like my Chevy work van, and I'm pretty sure that needs a rear end too. T100 also has a pretty decent vibration at 65-70 mph on the highway, goes away above 70.
I read a great page (Erik's) about diff types, and I'm looking for stock replacement advice/parts sources. I'm a competent weekend mechanic but I think diff replacement is above my pay grade. Any suggestions?
ALSO - Valve cover gaskets are leaking. Looks minor, but can make a stink. I need to buy a Haynes manual, and make a weekend of this repair. Anything else I should look at/repair while I've got the intake/covers off???
Horn- doesn't work. I haven't tested anything, but I understand electronics well. Do these trucks have a common failure point (horn pad, wiring harness, grounds) or is this a rare failure?
Thanks for reading this far- this looks like a great forum!
A few issues-
your vibration in the rear end is probably your u joint that needs to be changed, and the vibration between 65 and 70 is probably and alignment issue or u need your tires balanced but i'm leaning more to u just need to take your truck to get it aligned.
Yeah i think with the vibration it would be the rar u-joint. its a chap fix and lik the other guy said--probobly time for a change anyways.
but at th sam time i would get all the tires rotatd and balanced. because that can always make a huge difference. and with the rear end--just swap it out. its cheapest and easiest. you can find a used one pretty easily.
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
Vargntucson
Jul 4, 2015 12:15 PM
