PowerTrax Lock Right vs. Detroit EZ?
Hey guys,
I am going to go out in the morning to pick up a "pocket locker" and well there are the two main contenders- Detroit's E-Z locker and the Power Trax Lock Right. I was looking at Central 4WD's site where they list the Lock Right for $202.80 (V6/Turbo) and 4Wheel Parts lists the Detroit EZ for $248.00- Is there any fundamental difference in quality? Such as the Detroit being worth the extra expense for example? I need to replace my gasket on the 3rd member, so I had to drop it anyhow. What better reason to get a locker?
I run the Powertrax in the rear and am very pleased. I read a comparison once that helt the LockRight and EZ side by side and the observer reported that the LockRight appeared to be more carefully machined.
I'm a die-hard LockRight fan. You can't beat the price, the documentation is excellent, installation is easy and fun, the street manners are excellent, in my opinion, and it's a true locker off-road. If you put 140 wt oil in the diff, you can hardly even hear it click around corners. I've had no complaints on any surface--even snowpack. I don't regret a thing.
I haven't put one in front because I wouldn't be able to turn the wheel (I'm a lightweight with no power steering) and don't want to increase the chance of breakage, but I feel it's just the ticket for the rearend.
Eric
Eric
Quick Lok
Well I went to both Central4WD and 4Wheelparts today and I ended up with the QuickLok locker, which is the same as the the Detroit EZ locker, just under a different brand name, and marketed by genuine gear. It was $241. I am concerned because according to the Trac Tech catalog, there is a different part number than the one that they sold me. I show the one that they sold me as the 4cyl one, but the specs seem to read the same. 8" ring gear, 30 spline, 4x4 gas/turbo/diesel. What gives?
4cyl turbo/V6- G/g3028 (The one I should have?)
4cyl 4x4 gas/turbo/diesel- g/g3015 (The one that I have):pat:
Not sure on the part numbers but I'm pretty sure the one you need should be for a 4 pinion I believe, not 2. There should be a cross shaped cut out in the middle of the two pieces for the pinion, not just a straight line. Sorry if the discription isn't very good, but hopefully you understand what I'm trying to say.
Originally posted by L33T35T 4Runner
whats the difference between the powertrax no slip and lockrite?
I got lucky with mine......got it off ebay and only gave $140 (shipped) for it. It was practically brand new. I installed it myself and it took a total of about 6 hours from jacking up the truck to setting it back on the ground. Not hard at all to install.
ashamsuddin
17
Jul 22, 2024 03:59 AM
PNW94Runner
Sep 29, 2015 02:55 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
