93-98 T100s All T100 trucks
Rear Axle Seals - Revisited
Old Oct 30, 2006 | 05:55 PM
sworxx's Avatar
I know this was in an old thread, but certainly relevant.
http://www.trademotion.com/partlocat...97&catalogid=1
Are these the Toyota parts needed to fix the leaky axle seal? I am very surprised they are less then elsewhere, or are they incorrect? Anyone have the actual Toyota part numbers for these axle seals, o-rings or whatever they are called?
if these are the correct seals for the axle, it might make it easier for people to find them.
Ps. Mine are blown so I need the info as well.
Old Oct 30, 2006 | 06:13 PM
YotaFun's Avatar
Mine are blown as well...
The link however you supplied is not working in any of my browsers.....
BlackToySteve's Avatar
Your linky ain't working mate......not on my machine anyway......
Old Oct 30, 2006 | 06:20 PM
sworxx's Avatar
This one work?
Old Oct 30, 2006 | 06:21 PM
sworxx's Avatar
If not it was on Partznet.com under 97 Toyota T100 rear axle seals.
Old Oct 30, 2006 | 06:22 PM
Originally Posted by sworxx
Yup. Apparently my response must be at least five characters long....so....
Yup, yup.
Old Oct 30, 2006 | 06:23 PM
sworxx's Avatar
Is that yup, yup, meaning those are the correct seals to do the axle seal replacement job? Should anything else be done aside from the oil brake shoes at the same time?
Old Oct 30, 2006 | 06:44 PM
That was actually one yup, but needed two in order for the page to let me post.
If that is what the parts diagram says, then that's probably what you need.
What are "oil brake shoes" by the way? Yes, you may need to put new shoes in the rear drums and check all that stuff, also. Be sure your wheel cylinder isn't the culprit, though. You just might need to start tearing that thing apart and take a good look at it.
Old Oct 30, 2006 | 07:02 PM
sworxx's Avatar
Replace the diff fluid "oil" soaked brake shoes.
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Iceman4193
Jul 15, 2015 04:48 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
