94 22RE 2WD motor part out
1994 Toyota P/U 22RE 138,000k motor for part-out.
For whatever reason, the previous owners of my truck put a GM radiator in my truck, well it clogged and my truck overheated and blew a HG. This was less than a month after I got my truck to pass smog (replaced cat and MAF). It passed well under the CA regulations after those two parts so I figure everthing is in working condition.
Sold so far:
Trans/Engine stiffener brackets
EGR Valve
Lower intake manifold complete(injectors fuel rail etc)
Throttle Body and TPS
A/C compressor bracket
Spindles
Manifold
ECU
MAFS
Here's a list of a few parts:
Make an offer on any part you need from a 22RE.
Engine harness-$50
Toyota starter (4,000k)-$50
Mallory ign. coil-$50
02 sensors x2-$20
AC compressor-$50
2WD Transmission-$150
Manual steering box-$50
Whatever else was on that motor.
Will ship
Located in So-cal 92308
PM or reply for phone # or email.
I can't find my camera but I can still get pictures if you need.
Thanks for looking.
Edit: Forgot prices
Edit 2:
7.5" rear end, stock, drum 2 drum minus brake lines. $100
2WD spindles. $40
2WD hubs. $30
Edit 3: 2" lift shackles- $30
Edit 4: Tailgate, dark grey metalic, recently painted.
Sold so far:
EGR Valve
Spindles
Manifold
ECU
MAFS
Engine harness-$50
02 sensors x2-$20
AC compressor-$50
Will ship
Thanks for looking.
Edit: Forgot prices
Edit 2:
2WD spindles. $40
2WD hubs. $30
Not to sure what intake runners are, can you explain?
I had a cold air intake on and I do not have the stock airbox/piping ( if thats what your talking about).
Nathan
Nathan
Sorry, I was on my way out the door this morning when I saw your post. I am looking for the upper intake manifold that the throttle body attaches to.
Thanks
Robb
Thanks
Robb
The engine is still together, it blew a head gasket, and once the radiator fluid tested positive I stopped driving it, but it still ran.
how much for the harness and the in cab harness if you have that to with the computer and does your instrument panel have the oil volt temp tach and fuel style if so then how much to shipp to reno nv? thank you
I kept the body harness and instrument panel but I have the engine harness but I already sold the CPU.
Didn't have a stock intake sry.
How much for the engine itself? And are you CERTAIN it's the head gasket? I ask because I just spent the time to replace mine, only to still have water in the engine; the head or block must have cracked, though I didn't see it ... . I'm in Riverside County, so it would be a pretty short trip out there ...
Thanks,
Steve
Thanks,
Steve
hey bud im intrested in ur wiring harness and the ecu my my zip is 34481 fl get me a price on those items and shipping and get back with me
The deal on the motor is I got the temp very close to red one day. Once it climbed to past 3/4 I stopped and turned off the truck for about 1hr, then drove it 1mi back to my house. All through the week I started to loose coolant but there were no leaks on the outside and the oil was not milky, so it started to run rougher and rougher, so I took it to a shop and got the coolant checked. They tested the coolant and there were traces of oil found it it, so I took it home and checked the oil for the 10th time that week and now my oil looked like a milkshake. the motor still ran and had power, it just idled really rough. I stopped driving it the day I brought it back from the shop.
I'm not a motor man so rather than have someone rebuild my motor, doing a swap wouldn't cost to much more. I took the motor out in May '06 and its been in the corner of my garage ever since.
Here's some pics of parts I have in one box, check the SOLD items list in my first post to see what has already been sold. Thanks!!
Fan clutch: $20 shipped
Block/Trans plate: $25 shipped
SOLD
SOLD
Evap canister: OBO??
OBO on what ever this is
Sensors for EFI as shown in pic: $15 shipped
Harness has one cut plug. (the plug has a single wire that goes into the oil sender sensor): $50 shipped
SOLD
Igniter, I had it setup for an aftermarket coil (which is for sale too)
SOLD
SOLD
SOLD
bigblue82
10
Jul 6, 2015 08:27 AM
crazypaint
Jun 23, 2015 03:27 AM
