flooding
Old Sep 2, 2006 | 04:57 AM
goodoldtruck's Avatar
flooding
hey everyone i'm new here but i have an old toy with 245k on it and it runs great (well was), just did the head and timming chain and it ran awsome for three weeks then it started flooding when it idles any ideas what it could be
Old Sep 7, 2006 | 03:28 PM
flooding issue
ok my truck was flooding cause it wasn't burning the fuel i think cause all my plugs are wet with gas and barely firing anyone have any ideas what it could be i need my truck back plz reply
Old Sep 7, 2006 | 04:32 PM
Firefightertaco's Avatar
Check the timming
Old Oct 2, 2006 | 09:54 AM
runner126's Avatar
yeah check the timing but also check the plugs, my dad has an 84 truck 22r and had some trouble with excess gas not being burned, he changed the cap and rotor got new plugs (alittle better quality) and it works fine (the carb was at stock adjustments). Im sorry, this might be a stupid question, but does it have a carb or is it F.I.
Old Oct 2, 2006 | 09:57 AM
runner126's Avatar
im guessing a carb. (judgeing by the forum and assumtion its stock (no engine swap))
Old Oct 2, 2006 | 07:33 PM
leiniesred's Avatar
Blown accelerator pump diaphram
Old Oct 29, 2006 | 07:55 AM
84Yota's Avatar
Yah, I have a similiar issue, haven't solved it yet, but I have a lead. I had the EGR system off to check it and I had to pull a few vacuum hoses so I could get at something...and what did I find? Gas in a vacuum line! I'm 99% sure it shouldn't be there. The hose I pulled goes to the CB (choke breaker, another one of the diapragm activated devices on the carb), it's the one at the back right that has the "jet" inline (looks like an inline filter in the vacuum hose).
I'll post back if it is the solution to my rough idle/stalling/gas pouring out the exhaust issue. I haven't been able to run since the EGR system is off and I'm waiting for a gasket that they had to order.
Old Oct 29, 2006 | 09:56 AM
84Yota's Avatar
So just after I last posted I started studying the vacuum diagram...I bet it is the AAP (aux accel pump) diaphragm. Not sure if leiniesred meant AAP or AP? The CB shouldn't have gas on the other side...however the CB and AAP are essentially conected through BVSV for the AAP (cold engine only). Gonna check it today.
Might be something for you to check too. Sounds like we have similar issues.
Old Oct 30, 2006 | 08:32 PM
84Yota's Avatar
Yup that was it...
AP or AAP, either way, you're dumping extra gas into the intake...
AAP is cold engine only though...
Old Oct 30, 2006 | 08:40 PM
SoiledGreen98's Avatar
Awesome! I like working on carbs. Hopefully when I get get a new 4X it'll be an '84 - '85.
87blyota
Aug 23, 2015 03:57 AM
JustToynAround
Aug 19, 2015 11:46 AM
karbin
Jul 5, 2015 11:37 PM
