Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
wiring an alpine swr 1221d sub
Old Aug 6, 2006 | 11:41 AM
freshman's Avatar
how to connect this thing to a mono or 2 channel amplifier?
This sub (yes only 1) has dual voice coil which is 2 ohm each coil. 150 rms each coil.
What connection to make it 4 ohm? And whats the effect on its rms on this set-up?
Or when i leave it 2 ohm each voice coil running to each channel of a 2 channel amplifier? Is this safe for the sub/amp?
Last one, how can you make it to 2 ohm single wired sub to run into a mono 2 ohm stable amplifier?
I hope i dont confuse you guys and gals. :pat:
Old Aug 6, 2006 | 04:03 PM
NisAznMonk's Avatar
Nothing wrong with having only 1 subwoofer.
See the attached picture:
Depends on the amplifier. To make your situation easiest, just wire it up in a mono configuration. See the above picture.
You don't. That would only work if you had a Dual 1-ohm OR dual 4-ohm. Your subwoofer will only allow a single 4ohm or single 1ohm load.
Nope. Goodluck
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Mrhoadley
Aug 4, 2015 06:08 PM
Daneums
Jul 28, 2015 11:57 AM
