87 Runner: front locking hubs, manual or automatic?
Hellos All, which do you prefer, manual or automatic locking hubs? I've heard the automatic ones will burn up. Is that right? Like some feedback. Thanks......Jackman
The auto locking hubs had a lot of problems making them unreliable. Most people swap them out for the manual hubs. I believe they are stronger also but not sure about that.
personally, I prefer the manuals. it takes the guess work out of knowing youre locked in!
there are more advantages to using manual locking hubs than automatic ones (as long as you don't mind getting out your car to lock them). Theres less moving parts in the maunual hubs, so theres less to mess up making them more reliable. They also relieve some of the stress of your CV joints if your running IFS and give a tiny little increase in gas mileage while off road as well as giving a tiny boost in the torque at the front wheels when in 4wd. Also to lock the ADD hubs I think you had to go in reverse for a couple tire rotations, I've never had to do that with my manual locking hubs. So unless your trying to stay clean and pretty when off-road get the manuals.
Thanks fellas, that was my problem with the auto hubs, (getting stuck). I swaped them with some manuals from a 86 Runner and "man can you tell the difference." Lot of parts to switch out though, but worth it. Thanks again......Jackman
Originally Posted by Intrepid
An '87 didn't have ADD, it had auto hubs, there is a difference. IIRC, the auto hubs only lock while moving forward, so if you get stuck and have to go in reverse to get out, you are doing it in 2wd.
Originally Posted by toy4x4runner
Not true! The auto hubs would lock in both forward and backward, but you had to back up to disengage, and it didn't always cooperate. Also, the engage mechanism with the tabs to lock/unlock would regularly get bent by the dealer doing bearing repacks, so I swapped in Warn manuals.
http://www.4x4wire.com/toyota/tech/autohub/
It does say, however, that it will eventually lock again, so I suppose we are both right to some extent. Either way, this is the problem with these hubs.
Jun 1, 2021 01:51 PM
Poncho0206
Jul 10, 2015 06:21 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
