engine rebuild removal.
Old Jul 11, 2006 | 09:50 PM
Sonofmayhem's Avatar
ok, is it absolutely neccessary to remove the engine when doing a rebuild? ive heard both, but id rather to the rebuild in my driveway w/o a hoist, i figure engbuilders kit off of ebay and some machine work and the confidence of having stuff all done right. but i had a bent rod, what will be trashed? it only ran for about 10 min. at the most w/ the bent rod, just to a parking lot and on to a trailer. thanks
EDIT:: its a 22re 5spd 4x4
Old Jul 12, 2006 | 02:15 AM
ironroad9c1's Avatar
you have to take it out to machine it ....
Old Jul 12, 2006 | 02:45 AM
TNRabbit's Avatar
The best you can hope for is to jack it up inside the frame. If you don't know the extent of the damage, it's a good idea to pull everything apart and check it all. You don't want to invest a lot of time & $$$ then get it back together & discover you missed something that would have been easy to get to when it was apart....
my $.02
Old Jul 12, 2006 | 10:32 AM
surf4runner's Avatar
with some strong buddies you could pull it out w/o a hoist.
youll be happier if you remove it. tried it...once.
Old Jul 12, 2006 | 04:06 PM
toyotaoffroad91's Avatar
try to rent the hoist and just pull it it will be MUCH easier if no faster. a 22re can be pulled in less than an hour
Old Jul 12, 2006 | 04:15 PM
kyle_22r's Avatar
i dunno about "less than an hour"(maybe if you cut the wiring out?) but it's not hard to pull these engines. rebuilding one would SUCK while it's in the truck! hope you have some icy hot, your stomach and shoulders are gonna be sore after putting everything together in the engine bay!
it's much easier to do it with the engine on a stand.
Old Jul 12, 2006 | 08:08 PM
ok, i can get on base and borrow one, then im thinking about just getting a new truck and parting out this one, i know i could make plenty w/ a part out, but i would love to keep this truck its in great shape. where can i get the 2.7 swap equiptment? AA? Painless wiring? ORS?
Thanks
bigjstang
Jun 2, 2025 03:56 PM
jerusry
Oct 19, 2015 05:28 PM
Yota.Jay
Jul 23, 2015 08:08 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
karbin
Jul 5, 2015 11:37 PM
