Which fuse can I tap into that works on ACC (for stereo)
I want to get my stereo to work when the key is in accessory, the guy who wired the stereo before me didn't do me any favors, he cut the harnesses and ran his own wires...not a problem, except that I have NO idea what he was thinking when he ran them!!! It didn't matter at first, but I want to get tunes when in ACC mode...I can run a wire to anything in the car, what should I tap into for this? It needs to be a 15 amp or larger fuse for this to work. Better yet, what is the color of the acc fuse, or can I run it directly from a harness somewhere? I know there aren't too many 1st gens on here, but could someone at least tell me where to LOOK for the acc wire? I checked my chiltons but I couldn't find anything specific enough. I will post what I did find in a few minutes.
Okay, went through my Hanes manual, it wasn't exactly the same as the Chilton's, but that seemed to help. With the help of a test light, I found a wire that gets power in IGN and ACC so we're golden. I think.
this might solve your problem, useually on the back of your head unit there is a switch that says ACC or NO ACC and you switch it to whatever side if your ignition has an ACC on it or not. My switch is on ACC and my radio is on in ACC.
hope this helps
hope this helps
hey bro---
look right off the key cylinder-- there are 5 wires coming from it... you can tap into the black/yellow--that works off of ACC, and it is a 10guage wire, so current wont be a problem. unless you have a pullout deck from 1990, there wont be any switches for constant or acc wiring on it. connect the yellow from the deck to constant and the red to the black/yellow on the ign harness.
good luck
tim
good luck
tim
Log Gatos,
Look at my write up on the Valentine 1 in my sig. You'll see a clear picture in the write up of the wire DuffDog is talking about. As you will see, I followed his advice with good results.
Bob
Bob
ashersullivan88yota
Jan 18, 2022 05:37 PM
Suprarossa
Jul 6, 2015 05:21 AM
