quick 22re exhaust manifold question
Nuts or bolts?
I've been shooting pb blaster at what looks like nuts on my exhaust manifold for like a week now. Today (just now) I go out to try to see if they'll break loose, and on the first two I turn they're acting like bolts coming out of the head, not nuts coming off studs attached to the head. Since I was expecting to have nuts backing off, I tightened them back down, and they did seem to hold in, no signs of slippage/strippage. Then I came straight in here to say wtf??!!
Is this a bad sign, or can I just go with it?
Several of mine came out as well. I just took vice grips and got the nuts off them (took like an hour to do it too
) and screwed them back in the head and reused them. They were in perfect condition so there was no reason to replace them.
You can try using some locktite but it will probably just burn off.
It doesn't really matter if it is the nut holding the manifold or the stud. It's all good.
) and screwed them back in the head and reused them. They were in perfect condition so there was no reason to replace them. You can try using some locktite but it will probably just burn off.
jasonty
41
Dec 23, 2018 01:00 PM
icentropy
Jul 14, 2015 10:23 AM
