water pump metal gasket with seal packing
Old Jun 26, 2006 | 01:35 PM
4x4CPOSEADOG's Avatar
Hey guys,
I just bought a new water pump for V6 3.0L and I'm about to replace the timing belt. Now my question is do I still need to put some FIPG or RTV around the seal packing that is already incorporated in the metal gasket that came with the new OEM water pump?
I'm about to do this task this coming 4th of July week end. I did a lot of searched in here and a lot of reading. My eyes are getting read and tired.
I appreciate any info. Thanks.
Old Jun 26, 2006 | 02:36 PM
Tragic Drive's Avatar
The mighty FSM say's
WATER PUMP
Installation
1) Apply sealant on water pump sealing area. Install water
pump. Install and tighten bolts to specification. See Fig. 22.
2) Install thermostat with jiggle pin facing upward (toward
top of engine). Using NEW gasket, install coolant inlet. Install and
tighten nuts to specification. See TORQUE SPECIFICATIONS. To install
remaining components, reverse removal procedure. Fill cooling system.
Fig. 22: Installing Water Pump Bolts
Attached Thumbnails water pump metal gasket with seal packing-water-pump001.jpg
Old Jun 26, 2006 | 03:56 PM
mr toytech's Avatar
if the waterpump has the metal gasket it is a redesigned pump and no longer requires the fipg or sealer. just clean the old sealer from the block and install.
Old Jun 27, 2006 | 01:54 PM
Originally posted by mr toytech if the waterpump has the metal gasket it is a redesigned pump and no longer requires the fipg or sealer. just clean the old sealer from the block and install.
Thanks mr toytech, that is what I'm thinking since the metal gasket has the seal, fipg or rtv no longer required. Are you a toy mechanic by chance? Thanks for your info.
Old Jun 27, 2006 | 03:35 PM
FIPG is a small insurance on a part that can do alot of damge to your motor.
Do you really want to pull all that stuff back apart to repair a leak ?
LINK
,Thomas
Old Jun 27, 2006 | 03:43 PM
kyle_22r's Avatar
i no longer use RTV on gaskets, i've switched to permatex high tack sealer. used it on my water pumps, timing covers and everything(well, except head gaskets) and no leaks. easy to get off if you ever have to get back in there, too.
if RTV or FIPG gets loose it can cause major headaches...
Old Jun 27, 2006 | 04:21 PM
Tigerstripe40's Avatar
I use Permatex The Right Stuff.
I suppose it's pretty similar to the FIPG.
I've never had a problem with it leaking, where other gaskets, sealers, etc have leaked.
Old Jun 27, 2006 | 05:49 PM
I have in my hand is a Permatex Ultra Black Hi-Temp RTV Silicone Gasket Maker, is this good enough? Can I use this in addition to the seal that was already built in to the metal gasket that came with the new water pump? I have used a lot of red Toy FIPG on transmission pan, but not on water pump.
I don't know maybe I have to put a small beads around the seal to ensure no leakage.
Old Mar 11, 2007 | 08:50 AM
slosurfer's Avatar
Originally Posted by 4x4CPOSEADOG
I have in my hand is a Permatex Ultra Black Hi-Temp RTV Silicone Gasket Maker, is this good enough? Can I use this in addition to the seal that was already built in to the metal gasket that came with the new water pump? .....
I have the same question. My new toyota waterpump has the same metal gasket with built in seal, should I go ahead and put a small bead around the seal. I also have the same permatex as above.
smthwsn357
May 1, 2024 07:28 AM
Sep 4, 2015 09:27 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Nickdigg
Jul 7, 2015 06:04 AM
