93-98 T100s All T100 trucks
T100 Gears
Old May 24, 2006 | 08:33 AM
Nasty100's Avatar
T100 Gears
Does anyone know the ratio for stock gears in a 2wd 95 T-100... and what gears would be recommended when running 33's or 35's
Old May 24, 2006 | 04:22 PM
Elton's Avatar
i think you may have 3:73s not 100% sure .... also 4:88s is what you want for 33s and pretty sure it will be ok with 35s
Old May 25, 2006 | 01:06 PM
mrvoodoodaddy69's Avatar
I have a 4x4 with 4:30's and about a 32" tall tire that works well. I'm sure it would be fine w/ 33"s. so a cheap route would be to find a 4x4 with the big tire package @ the boneyard and swap the whole differential set-up. And if going to 35's I would probably do 4:88's.
here's a link you can compare tire size and gear ratio to rpm's @55mph
http://www.fourwheeler.com/techartic...TS/index3.html
Old May 29, 2006 | 04:15 AM
Nasty100's Avatar
Hey thanks for all the advice i think i'm going to do some more research on some 4:88's
jashoeuh
Nov 18, 2024 08:08 AM
polo451
13
Nov 20, 2016 07:49 PM
kouki420
Sep 2, 2015 11:42 AM
rustym
Aug 7, 2015 10:39 AM
jgwerth
Jul 16, 2015 03:23 PM
