doors
I have a pickup that is a '91 model pickup so i believe they are the same and if so (and if you dont have power windows or locks) it is just four bolts that bolt the hinges to the door on each side. I believe they are a 12 mm. It is easiest to take them off if you have a set of ratchet wrenches because it is the easiest way i have found to get to it.
i can unbolt them but unfortunately i have power windows and locks and was hoping to see how people unconnected their electrical and made it so they could plug it back in again. thanks for your help though
Originally Posted by MorphiasX
They have plugs right inside the door I believe. I think its two or three plugs for each door. Pull the kick panel and see if they do.
The plugs are inside the cabin, behind the kick panels and higher than where the grommit comes though the pillar. they are a pain in the butt to get out.
Originally Posted by DeathCougar
nope, that is incorrect.
That is not incorrect. I meant right inside the doors as in right inside the cabin from the door. That is why I mentioned pulling the kick panel to see. Obviously, he understood what I meant since he said "Thanks" implying that he found it.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Odin
Sep 26, 2015 06:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
