Who all makes BJ Spacers?
Old Mar 23, 2006 | 08:21 AM
Injohneer's Avatar
OK, I've decided to rebuild the front end using the kit from arm_can on ebay, and some BJ spacers.
Seems like everyone is running BJ spacers, but nobody says where they got them. The only ones I have found so far are:
4Crawler's and SDORI's -wait aren't these the same?
Does anyone else make bj spacers for the 'runna? And who's had good or bad experiences with them?
Old Mar 23, 2006 | 08:26 AM
tc's Avatar
tc
Can't go wrong with 4Crawler...
Old Mar 23, 2006 | 09:41 AM
Silver_Truck's Avatar
SDORI makes em all. 4 crawler and TRDparts4u are just vendors for em
Old Mar 23, 2006 | 10:05 AM
BLKNBLU's Avatar
Yeah what he said. They are all sourced from the same place (SDORI). You can't go wrong with either vendor either. I've dealt with and had great service from both. I couldn't get the link to work for purchase over at SDORI but of the other 2 TRDparts4u is cheaper but Roger will customize them (i.e. cut them down a bit) for you if you desire. I believe most people have them in as manufactured (I do), so maybe someone with more experience can chime in as to why one might want them cut down. In my case I got them quite some time ago directly from SDORI in a group buy.
Mike
Old Mar 24, 2006 | 05:00 AM
Injohneer's Avatar
OK, next question:
If you are running (or did run) BJ spacers, what shocks did you run?
Were you happy with them?
I'll be starting out with the stock torsion bars, and won't upgrade those until a heavy front bumper or engine swap forces me to... (sometime in the next 5-10 years...LOL)
Old Mar 24, 2006 | 05:26 AM
cootees's Avatar
Shocks vary. Most people run rancho or ome. There is a huge thread for the bj spacer/lc coils shock part numbers.
Old Mar 29, 2006 | 12:13 PM
-MaTTi-'s Avatar
I like them, nothing but good to say of them. Shocks are Monroe Gas Magnum, they are a little bit too short... so I don´t recommend them.
Old Mar 29, 2006 | 02:10 PM
Injohneer's Avatar
Ha, I think those are the shocks I have on front, too... eh, I'll probably add enough washers to make it work until a few more paychecks come in. Then I'll probably do Ranchos to match my rear shocks...Oh, that, and the IFS truss...
Old Mar 29, 2006 | 09:08 PM
BLKNBLU's Avatar
I have Rancho 5167 up front 10.25 compressed and 15.25 extended. After I got those I found these on ebay and have some on the rear and they seem comparable at a much lower price.
http://cgi.ebay.com/ebaymotors/Super...14372343QQrdZ1
Each ad has a link at the bottom to a spec guide where you can check lengths and mounts. I think the 787011 I linked to is close but you can check it out for your self.
Mike
Old Mar 29, 2006 | 09:19 PM
Tofer's Avatar
Sponsor
if you put in BJ spacers look into manual locking hubs and/or a 4crawler diff drop. i blew out a couple CV boots after installing mine until i got both those installed.
Old Mar 30, 2006 | 10:56 AM
Injohneer's Avatar
Already have the manual hubs... but thanks!
Old Mar 30, 2006 | 04:04 PM
Lunnzz's Avatar
This kit ain't bad I e-mailed somebody who bought one and said he had no issues it's the one I am eventually going to get.
http://cgi.ebay.com/ebaymotors/SUSPE...2243QQtcZphoto
Old Mar 30, 2006 | 05:03 PM
Diesel_Freak's Avatar
what exactly is the total lift there?
Old Mar 30, 2006 | 06:31 PM
Injohneer's Avatar
Mike
Hey, I didn't see this post earlier! Wow, those are cheap!
Hmm, I will definately try those out. One question, when I put my Ranchos on the back, they had a smaller eyelet on the bottom end of the shock than the mounting peg... did you have the same problem with these? I didn't see any size for the eyelet listed.
Thanks!
Old Mar 31, 2006 | 06:45 AM
BLKNBLU's Avatar
Thanks!
No problem with mine. They bolted right up. They did have a funky 1 piece hourglass shaped bushing that was kind of hard to get in without a press or vice. I ended up using the truck frame and bottle jack and it popped right in.
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
ksmudrunner99
Jul 21, 2015 05:33 AM
