wheres a good place to get a rear locker for a 94 2wd?
I'm sure you have heard this a few times already but you would be better off selling and getting a 4x4. I don't know what the locker selection is like for 2wds but if you don't install it yourself it's going to cost something like $500 for parts and labor. That $500 or so is the difference between a 4x4 and a 2wd in roughly the same condition.
momentum = speed and speed = good! thanks for the heads up. the only thing about speed is it can cause alot more damage and if you hit a big mud puddle too fast .... well, engines dont like water in the intake.i learned the hard way.im going to make a snorkel that gets air from inside the cab.
btw tc i grew up in south dayton, oh .. i miss that place.
Depends on what kind you get - check out the Locker FAQ sticky. "Lunchbox" lockers just replace the spider gear setup. Others replace the whole carrier assembly. If you go with a full case (Like Detroit Locker) it's a good time to consider regearing.
bigblue82
10
Jul 6, 2015 08:27 AM
cchinny
Jun 25, 2015 08:11 PM
XtremeOff-Road
16
Jun 27, 2002 07:32 PM
