newer pu box exchange
I have an 84 toy 4x4 pu with a rusting out box I'm wondering if anyone out there has attempted to switch to a new (seamless) box. Thanks, rj
new p/u box
I've got an 85 w/the same problem. I heard 89-95 will fit w/some minor tweeking. My next box will probably be this www.bruzerbox.com . What is a seamless box BTW?
Paul
Paul
89-95 don't have the seam for the lower half of the outside panels. That line where the box rusts and falls apart...
toyota bed
even the 79-83 beds will fit on the 84 -88 trucks all the bed mounts line up the same. i did it to a 79 4x4 i was fixing to sell i put a 85 4x4 bed on it. 2wd beds are the same just the wheel opening is a little different. the 89-95 beds will fit the 84-88 i'm doing that swap onn a 84 extended cab i'm fixing now. the bolts line up the same on them years to. so he could use any year bed from 79-95 you need the metal gas filler that bolts to the bed. it's different for the different body styles
newer box
Thanks for the impute guys. I'm going to be looking for an 89 or newer box so I can avoid the seam problem. rj
Gone Fission
Sep 4, 2015 12:18 PM
