22re driving me crazy!
Old Feb 10, 2006 | 06:05 PM
John79's Avatar
Its a 89 toyota pickup with a 5 speed and 22re. Problem seems to occur at random but if I try to drive for any lenght of time it will eventually happen. It idles goofy and goes up and down. When I drive if I go over half throttle in any gear it will start breaking up and check engine light flickers. If it dies or I shut it off when this happens it will not start again unless I give it a shot of starting fluid. Then it will fire up and run again. I replaced the fuel filter, spark plug wires and the cap and rotor, tps and air flow sensor where recently replaced. Its very frustrating cause it will be driving fine then do this then drive fine again later.
any help would be appreciated thanks
Old Feb 10, 2006 | 06:09 PM
regularguy412's Avatar
Did you pull the ECM codes to see what error the CEL was giving you?
Mike in AR
Old Feb 11, 2006 | 01:52 AM
Tacoma Dude's Avatar
Have you ever replaced the fuel pump? It doesn't sound exactly like the issue I had before I had to replace mine but it does sound like a fuel delivery problem.
Old Feb 11, 2006 | 06:15 AM
Maverick's Avatar
Check your raidator fluid, when my throttle started jumping it was my head gasket that had blown or had a leak and there was exhaust in the raidator fluid. Have someone test your fluid for exhaust gases.
Old Feb 11, 2006 | 02:01 PM
John79's Avatar
I got a code 14 but it was still getting spark. I don't know if its the fuel pump or not I jumped the Fp and b+ terminals and could hear the fuel pump running when the ignition is on but it still does the same thing even with the fuel pump terminals jumped.
Old Feb 14, 2006 | 09:48 AM
Tiger Paw's Avatar
When is the last time you changed your plug wires? The insulation wears thin quicker on cheaper wires, too. They'll look o.k. or possibly dry-rotted, but they'll be too thin to keep them properly insulated from each other.
Old Feb 15, 2006 | 04:09 PM
John79's Avatar
i replaced the plug wires and it didn't help at all. I believe the problem is the pickup coil in the distributor it tested fine cold but I tested it again when it was warmed up and started running badly and the ohms weren't in spec so I ordered a new one and hopefully it will be fixed finally.
Old Feb 17, 2006 | 04:13 PM
Tiger Paw's Avatar
So did the new pickup coil fix your problem? Just wondering so in case anyone does a search they'll have a few possiblities narrowed down. Hope it did fix it, though. It's nice when it's something minor.
Old Apr 14, 2009 | 12:27 PM
dillsmack's Avatar
i have the same problem........ help what was the result?
i've got the same problem exactly like how you described it. What did it turnout to be?
Old Apr 16, 2009 | 07:57 AM
abecedarian's Avatar
Had a similar thing happen on my 88 and it was the igniter failing.
Old Apr 16, 2009 | 05:42 PM
tysen86's Avatar
I say fuel pump. It can be running and not putting out the pressure or the flow thats needed.
Old Apr 18, 2009 | 04:06 AM
PhilR's Avatar
The same problem happened a few times in my 1990. It even happened when I went for a test drive before I bought it... I didn't try to figure it as I have another good running 22RE that I want to install in it when this one dies (or maybe before!). The "check engine" light stays off when driving.
Old Jun 14, 2010 | 09:35 PM
manch0690's Avatar
I have a 1991 yota 4x4 4cyl I call her betsy She keeps pulling code 14 i have replaced the cap rotor plugs wire and coil and she is getting spark runs fine when she first statrs then fine if you are driving but once you stop her she will just die when i get to like 5mph-15mph she will start back up and if i keep giving her gas she wont die untill i back off the gas then she will bog out and die i have also droped the tfuel tank and cleaned it out and replaced fuel filter and maf and my fuel pump is good and strong i also just smogged it two weeks ago and passed no problem help code 14 is there a relay or a way to test igniter i tried one at the junkyard and it still had the same problems please help
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
