22RE In 92 PICKUP??
22RE In 92 PICKUP??
Hey all,
Im thinkin bout buying this 92 toyota pickup 4cyl 5-spd deluxe ext. cab pickup. I have done some searching but am still confused about the 22re, and the 22r engines and what year/model they came in... Does this particular truck have a 22re.. i heard that only automatics have them?? is that true?? any help would be greatly appreicated...
thanks so much
thanks so much
You definately have a 22RE.
http://www.4x4wire.com/toyota/faq/parts/
awesome thanks...
it has 160,00 miles... no rust... looks clean im thinking about calling the guy tomorrow...new tires...ext. cab, deluxe... hes asking 3500 or best offer... good deal??
i paid 4200 for an 89 with an automatic and the 22re and I am happy, take it to a mechanic for a once over and pay the man if it passes within reason. I assume it's a 4x4, if not, the price is still good. SR5?
yes it is a 4x4! thanks for the help guys.. im just a lil excited... now i need to figure out what im gonna do with my 4runner?? hmm.... i can think about that later... i wish i could sell it before i bought this but not sure i have enough time.. i will definately take it to a mechanic... thanks so much!
The EFI 22RE was used in trucks beginning in 1985. It uses the same crank and rods as a pre-1985 22R but has dome top pistons, a taller deck height on the block and a shorter deck height on the head. As a result, the oil pump, timing cover and timing set are also different.
There was an EFI 22RE made from 83-84 that was used in Celicas. That one has an identical lower end as the 22R with a different head.
Unfortunately, I found all this out the hard way. I ended up with a 83-84 22RE that I can't really use.
Sep 4, 2015 09:27 AM
