95 4RUNNER Gurgling sound
Old Jan 30, 2006 | 11:37 PM
Sapo's Avatar
I just checked out some previous threads about gurgling sounds under the dash because my 95 4Runner just started to make something similar. I noticed there was some talk about not reusing hte head bolts again after replacements of gaskets. Why is this so? I just had the rear main seal replaced after a huge oil leak and I'm wondering if the mechanic did reuse the bolts unknowingly.
thanks
Old Jan 31, 2006 | 01:08 AM
leebee's Avatar
if he is a certified mech and reused the bolts...
it could be as simple as the cooling system hasnt been properly 'burped' to ensure all the air is out. use the search button and look for cooling system or flushing cooling sys or similar and you will have plenty of info to help find and correct your problem.
lee
Old Jan 31, 2006 | 04:20 AM
UKMyers's Avatar
Can you just confirm that you did not have this noise before having this work done? Also please put your rig information in your sig so we can better help you out. There is alot of differences between the 3.0 and 3.4. Most AFM's(Mass AirFlow Sensor) on the 3.0 make a weird gurgling noise at idle. Mine became really noticable after doing some intake mods but was there when I was stock as well.
Old Jan 31, 2006 | 06:29 AM
runethechamp's Avatar
Don't know about your gurgling sounds, but the reason for not reusing the head bolts would be that they are torqued past their elastic range, i.e. they are permanently stretched once they are properly torqued.
Old Jan 31, 2006 | 07:31 AM
sandcrawler's Avatar
i agree with leebee; sounds like air in the cooling system. mine used to do it a lot, then i flushed it and it stopped. however, it still does it a little bit occasionally.
Old Feb 3, 2006 | 12:21 PM
cricket's Avatar
I have a 93 V-6 truck...I noticed the gurgling, too. The coolant was a little low, so I topped it off and the gurgle went away. I think low coolant makes the heater core gurgle...it was especially noticeable at medium heat settings.
Crick
Old Feb 3, 2006 | 12:39 PM
celica's Avatar
Crick
That will be your sound. Common with the 2nd gens. I have always had it, mine is not really a gurgle but a ruch of fluid when I start the truck - totally normal
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
