my brakes squeek...
Old Jan 30, 2006 | 09:41 PM
4ROMPER's Avatar
my brakes squeek...
only when i'm driving. not when applying the brake- then it is silent. Whats that all about?
Old Jan 30, 2006 | 09:55 PM
Yota4runner's Avatar
You sure its the brakes? Could be a leaky caliper. or a loose caliper for that matter. taken the tire off to have a look yet?
Old Jan 30, 2006 | 10:06 PM
linuxrunner's Avatar
i had this for a long time... it was this little metal clip that helps you masure how much brake pad you have left or helps get it off, i am not sure. Anyway, it was rubbing on the rotor as i drove. but it is a small piece, like a paper clip so it just made a annoying squeek.
Old Jan 31, 2006 | 07:29 AM
eric-the-red's Avatar
Those little metal clips are there to warn you that the pads are getting to their wear limit. Pull the wheels and check the pads, they'll probably be ready for replacement.
Old Feb 2, 2006 | 08:26 AM
4ROMPER's Avatar
sweet. makes sense, but i've never had that on my other vehicles.
Old Feb 2, 2006 | 08:45 AM
i have replaced the pads since then, I was just saying that they can become bent and rub on things causing a squeak but mine didn't squeak when I was going under 25. Thanks for the heads up on the clips; I knew they were for something.
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
