Tuning Issue - Stuck in Closed Loop???
Old Jan 29, 2006 | 07:28 PM
yoda-g2's Avatar
Finally getting around to tuning my URD kit and I'm noticing that when my rig first starts and is cold that it stays in Open Loop for a few minutes then switches to Closed Loop. Sounds good right? Well the weird thing in that when I have it at WOT it just stays in Closed Loop. I just pulled a big hill and had it at 7psi floored and no open loop.
I'm using the OBD Diagnostics tool that URD sells and running just the fuel trim and Open/Closed loop scanning (3 Lines). One thing to note is that when I select the TPS monitor it only reads 70% at WOT. I've verified that the butterfly is opening all the way at WOT.
Do you think:
A: The OBD scanner is giving me bad info, maybe too slow to refresh??
B: TPS calibration issue?
C: Gremlins?
Any thought would be appreciated. I'm not into my open loop tuning phase yet (still getting the closed loop tweaked) but I want to get this figured out before I get there.
Thanks!
Old Jan 30, 2006 | 01:10 AM
Toysrme's Avatar
Cool
That's what I think. Weasy?
Old Jan 30, 2006 | 07:14 AM
Weasy2k's Avatar
TPS Calibration wont affect the open/closed loops as its ecu controled.
What i would do is have someone else go into the engine bay and while in park have him/her quickly snap the throttle to full open to see if the ecu goes into open loop, if it does then you got a problem still in your gas pedel connection.
Are you holding the Threottle open long enough for the software to refresh? Also do you have a wideband sensor at all? Or even a AFR gauge (dancing light gauge)
Old Jan 30, 2006 | 06:46 PM
yoda-g2's Avatar
I held it at WOT for a good 4-5 sec. about 5 times. Any more and I would've been asking for a ticket. I do have a wideband, but I do not have it hooked up yet. The bung is in place, I just have to do some wiring. I'll give you "have someone hold it open" tirck when I get a chance and see what happens.
Old Jan 30, 2006 | 10:34 PM
Weasy2k's Avatar
the reason why i ask about the wideband is because using the wideband unit you can see the AFR...and tell if its in open/closed loop.
Old Jan 31, 2006 | 11:47 AM
yoda-g2's Avatar
What exaclty would tell you that? Will there be an obvious break from Stoich? I've never seen one in action but I assume that in closed loop the AFR should read 14.7 pretty consistantly right?
Old Jan 31, 2006 | 01:29 PM
Weasy2k's Avatar
Normaly the ecu will go between 14-15afr while in closed loop as soon as it jumps into open it will go to a much richer (normaly) mixture and you will notice it right away
Old Jan 31, 2006 | 11:51 PM
TomCham's Avatar
The AFR be changed to approx 13:1 in open loop (with no fuel upgrade kit). Is there a way to alter the close loop set up in the standard ECU?
Old Jan 31, 2006 | 11:59 PM
Weasy2k's Avatar
Do you mean aler the time it comes on or the afr in open loop?
Its yes in both cases anyway
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
lfcarrion3
Jul 18, 2015 04:05 PM
nick b
Jul 11, 2015 04:38 AM
Poncho0206
Jul 10, 2015 06:21 PM
