Gas gauge won't work on 99 4Runner
Old Jan 28, 2006 | 07:48 PM
krue's Avatar
My gas gauge either reads full or empty, nothing in between. Is there any way to test the sending unit without dropping the tank.
Old Jan 28, 2006 | 08:12 PM
northfacer581's Avatar
very popular topic. search.
https://www.yotatech.com/forums/f2/how-access-fuel-sending-unit-99-a-65310/
Old Jan 30, 2006 | 07:37 AM
cracker_1's Avatar
I had a problem with our gauge not reading below 1/4 tank. After dropping the tank and examining everything, I found out that our sending unit had a bad ground. You can check this without dropping the tank, Simply remove the access cover under the rear seat and attach an external ground to one of the sending unit attachment screws. See if this helps.
Old Feb 2, 2006 | 04:25 PM
krue's Avatar
Thanks, the ground may be it, I removed the cover and unplugged the connection just checking everything and now it shows signs of life.
zd92655
Mar 6, 2022 12:58 PM
Cesarl74
Apr 23, 2016 06:07 PM
Niameyrider
Jun 25, 2015 05:50 AM
gog1968
Jun 22, 2015 05:55 AM
