NAPA Freeway Blaster horns
Old Mar 11, 2003 | 09:41 AM
Corey's Avatar
Co-Founder/Administrator
These are also made by Fiam I believe, but I'd have to check mine.
I have got a few requests in the past (and today) for the part #s for these horns which are quite loud.
Local auto stores that carry NAPA parts should stock these, but quite often as is the case the part #s they have don't coincide when you try and input the # on NAPA's website.
Freeway Blasters
High pitch = 7301057
Low pitch = 7301056
They are rated @132 DB.
I only have one vid of these, and it does not do the horns justice.
http://64.127.247.125/tando/horn.mpg 447 kb.
They are a lot louder than the appear.
I also have mine hooked up via a 30 amp relay which is the same as the ones I use for my 3 sets of lights.
The stock horns are wired so that when you push the button on your steering wheel, it does not apply + voltage, but completes the ground.
Toyota uses a weird system for a lot of stuff.
When I first hooked these up a few years ago, I about dropped a load
As soon as the horns body touched the frame, off they went, hence the reason for wiring these through a relay instead.
I am using the stock blue power wire, and it goes to the relay, then the + wire from the relay goes to the horns, and the horns themselves are grounded to the frame via wires.
Not sure if you have to use this method on a newer rig, but with an older one like mine, the relay system works best, and also provides better current to the horns.
Old Mar 11, 2003 | 10:04 AM
Bob_98SR5's Avatar
Corey,
Man, thanks for reminding me! Though my Hella Supertones are loud enough, they are a bit "European-ish" for me. Those honkers of yours "fit" the 4runner.
How much did you pay for the horns? Do you have any pics of them mounted?
Bob
Old Mar 11, 2003 | 10:22 AM
Corey's Avatar
Hi Bob, the only pic I have is this one.
http://www.toyotaoffroad.net/tando/e...ash/clean1.jpg
You can see the custom bracket I had to fab up for the drivers side one.
The passenger side horn fitted right up to the stock location, and that is where the blue power wire was I tapped in to route it to the relay.
I'll have to get better horn pics sometime and update my page with the info and part #s.
I can't remember the price, but the store just quoted me $18.88 each.
I think I paid a little less a few years back, but maybe only a buck.
So roughly $40 for the pair after tax.
Cheaper than the Hella Supertones.
Old Mar 11, 2003 | 10:34 AM
Bob_98SR5's Avatar
Corey,
Thanks for the pic. I can see where the blue wire is running to and I think I know where you mounted them.
Question: are they trumpet shaped horns? And you pointed them downwards, right?
Bob
Old Mar 11, 2003 | 11:33 AM
Corey's Avatar
I'll see if I can dig up the info.
Oh, I mispelled it earlier also.
It's Fiamm, with two "m"
http://www.fiamm.com/en/index.php
I think these might be like mine, it's been a few years, and I can't really remember if they say NAPA on them, or Fiamm.
http://www.fiamm.com/en/2/prod.php/6;11
Old Mar 16, 2006 | 05:04 AM
ken.vs.ryu's Avatar
Can I just add the low note to the truck and use the oem as the high?
kcaudill
Oct 10, 2015 02:39 PM
Obmi
Oct 4, 2015 11:30 AM
the_supernerd
Oct 1, 2015 09:20 PM
Scotttekoch
Sep 28, 2015 10:30 PM
rmill05
Sep 27, 2015 01:43 PM
