Fuel Gauge Help 22RE
Well my fuel gauge stopped working a while back. It started slowly.
At first, It woudl show Full when I filled up and then about 25 miles later it would show empty (I get about 300 on a tank and about 200 till it used to say empty).
Now the gauge doesn't even move. I swapped the fuel gauge and battery gauge (SR5 cluster) for a new (different) one and it has the same problem.
What can I check to fix this? What parts might have failed.
I'm noit sure what wiring and components lead up to this ever important indicator.
Any help would be greatly appreciated.
Sounds like whatever your problem is...that it is on the other end in/on the tank w/ reading the correct fuel level. You got a FSM? I could go look in mine and see what it says...I'm sure it would be the same since I got a 22RE in my 85.
Originally Posted by bob200587
Don't bother with it....who needs a fuel gauge?
Wabbit- any info would be greatly appreciated.
I have seen the access panel under the rear seat, but I am eager to remove it
you can't have mine since it doesn't work either, but if it did you could have it......Its easier now for me to tell how much gas I have by miles than with a gauge.
Oh, The panel under the backseat is just screwed on and has a gasket thats kinda like RVT sealant. Its nothing to take it off and on. I did it just to see what was under there back in the day.
As for price of the Fuel Sending Unit- I paid about $80 at the stealership. If money is tight, check out this thread:
https://www.yotatech.com/forums/f2/3rd-gen-fuel-gauge-problem-i-think-i-figured-out-problem-pics-60260/
That thread leads me to believe that cleaning the contacts on the FSU might fix the problem, at least temporarily. Since I had to drop the tank on my pickup, it was worth it to me to replace the whole unit.
On mine, once the tank was down, it was a matter of removing 4-5 small bolts which hold the FSU to the top of the tank, unplugging the FSU, then installing the new one. My FSU looked like a round plate on top of the tank with wires coming out the center. If you don't have to drop your tank, it would only take about a half hour or so to change out, so it might be worth it to try some electrical contact cleaner first.
Good luck-
Scubaduck
Good luck-
Scubaduck
Originally Posted by deathrunner
I wonder if I could find a FSU cheaper than 80.00. That would be cool.
just so you know i have a 88 4runner with the same problem, but i can't access the sender guage from the access pannel under the seat, that allows access the the fuel pump, the sender guage is about 6in past the access pannel so you would have to drop the tank to remove it. that is the only reason i have to replaced it yet. but if my pump goes out it should be real easy to replacd
what kind of condition is the contact in? i could be very interested.
